ASR1002 odd layer 2 behavior
axl8227
I am facing an odd layer 2 behavior between 4 Cisco Router ASR1002-HX connected at the same Cisco Catalyst 2960 within the same vlan. Randomly each router can't reach the others within the same local vlan.
No layer 1 issues are present.
We face the same issue trying change L2 switch, sfp, cables, vlan, ip addresses, removing any L3 protocol and static route, clearing arp and setting static arp entries.
Updating the firmware from 16.3.3 to 16.3.6 did not solve.
Did someone ever face the same issue?
16 Replies 16
what is the uptime of the switch ? And the CPU utilization ?
Uptime is 3 days, 23 hours, 36 minutes
Resource                 Usage                 Max             Warning         Critical        State
RP0 (ok, active)        H
Control Processor       1.20%                 100%            90%             95%              H
DRAM                         2393MB(15%)     15921MB      90%             95%              H
ESP0(ok, active)        H
QFP        H
TCAM                     14cells(0%)           1048576cells    45%             55%             H
DRAM                    523150KB(12%)         4194304KB       80%             90%         H
  IRAM                   9942KB(7%)            131072KB        80%             90%             H
