02-23-2014 02:11 AM - edited 03-07-2019 06:22 PM
I have used all ethernet port on my ASR-1006 and i need more ethernet port, can you tell me how i can add this and whitch model of this interface can i use?
Solved! Go to Solution.
02-23-2014 02:14 AM
Go to Table 1 and look under Ethernet SPA.
http://www.cisco.com/c/en/us/products/collateral/routers/asr-1002-router/data_sheet_c78-443175.html
02-23-2014 06:39 AM
What do you mean by used all of your Ethernet Ports?
With the ASR 1006, you will have a SIP, which basically provides the electrical connection to the SPA cards. The SIP will come in a variety of models.
For instance, if you used a SIP10, how many SPA cards and what types do you have installed?
The links that Leo provided should give you a good reference point to find the SPA that is right for you as well.
02-25-2014 09:47 AM
If the CIsco 2-Port Gigabit Ethernet SPA is enough for you, it will be a lot cheaper than the 10 port.
Also, this port is a combo port, so you will have two copper and two fiber. Remember to use 'media-type' commands as well.
I would recommend the following SPA card (unless you need more ports)
Cisco 2-Port Gigabit Ethernet Shared Port Adapter, Version 2 |
Ifyou go all the way down to the bottom of this link, (or close to the bottom), you will see compatible SFPs.
Pick the one that best fits your needs.
02-23-2014 02:13 AM
02-23-2014 02:14 AM
02-23-2014 06:39 AM
02-24-2014 02:54 AM
Thank you very much for your help. I need to order for new SPA
02-25-2014 08:37 AM
hello
I have to order for below Gigabit Ethernet SPA and in need to confirm wich SFP optics i will choose, i am looking for Copper (RJ-45) SFP optics i need to confirm
Cisco 10-Port Gigabit Ethernet Shared Port Adapter
thank you in advance for your help
02-25-2014 09:47 AM
02-26-2014 01:46 AM
Thanks John for your clarification
I need more then two port and I am going for Cisco 10-Port Gigabit Ethernet Shared Port Adapter
is this SFP compatible with:
Name Part Number
1000BASE-T SFP (5-, 8-, and 10-Port GE SPAs) SFP-GE-T
Thanks.
