FEX powersupply shows Fail/Shutdown
I have a FEX that shows Fail/Shutdown when I issue the command show environment fex.  However, the status light of the FEX power supply is green.  None of my other FEXes show this behavior.  Can someone shed som light on this?  Has the PS failed or is there a command I can issue to bring it back online?
Please remember to select a correct answer and rate helpful posts
Joris Deprouw
Hi Marius,
Do you know the reason of this failure by now? How did you resolve this issue.
I've got the same alert on one of my fexes.
Best Regards,
Joris
