12-31-2013 04:48 AM - edited 03-07-2019 05:19 PM
I have a customer that wants to evaluate AdvancedMetroIPAccess license on their ASR901 device. After installation of the license the device wont boot with the relevant feature set.
Our customer is experienced engineer that did the installation of an evaluation license. He also followed the required procedure regarding license installation.
Here is the ouput of "show license" and "show license detail":
asr901-lab#sh license detail
Index: 1 Feature: IPBase Version: 1.0
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Index: 2 Feature: NGMWR-AdvIP-Eval Version: 1.0
License Type: Evaluation
License State: Active, Not in Use, EULA accepted
License Priority: Low
Store Index: 1
asr901-lab#show license
Index 1 Feature: 1588BC
Index 2 Feature: Gige4portflexi
Index 3 Feature: 10gigUpgrade
Index 4 Feature: AdvancedMetroIPAccess
Index 5 Feature: IPBase
Period left: Life time
In the document http://www.cisco.com/en/US/docs/wireless/asr_901/Configuration/Guide/lic.html#wp1094927 i found out the following:
" In Cisco ASR 901, IPBase (SL-A901-B) and AdvancedMetroIPAccess (SL-A901-A) are permanent; once installed they do not expire. Trial or temporary licenses are not supported on the Cisco ASR 901 router. "
Can someone clariffy for me if AdvancedMetroIPAccess evaluation license is available for ASR901.
Feel free to recommend any suggestions.
Thank you,
Srećko
12-31-2013 05:19 PM
In this case the Cisco ASR 901 router supports permanent licenses only. No evaluation licenses are available for the ASR 901.
http://www.cisco.com/en/US/docs/wireless/asr_901/Configuration/Guide/lic.html#wp1089389
Hope this helps.
01-02-2014 01:01 AM
Thanks Leo.
01-02-2014 07:28 PM
Sure no problem, just remember to rate all helpful posts in the community.
