Assign Public IP to LAN Computers
hyouhaku2
Hi, I recently purchased the RV180 router and right now it acts as the NAT gateway of my network.
My questions is, what is the proper way to assign let's say 5 public IP address to 5 machines inside LAN?
The router has LAN IP of 192.168.1.1 and public IP say 121.121.121.121-125
LAN computers have IP range 192.168.1.x
My approach was to have one-to-one NAT, mapping 121.121.121.122 to 192.168.1.32
and 121.121.121.123 to 192.168.1.33 and so on
It works so far but the problem is that if I try to access those public IP from inside LAN, they all point to the router, and I can't find any tool to redirect traffice unless modifying host file on each computer. So I guess there's better way to do this?
Thank you in advance.
Jeff Van Houten
Level 5
Level 5
Why would you want to access the public ips from the internal network? Setup dns internally and use the internal addresses to access those services.
thank you Jeff.
I have about 50 domain names pointing to those public IPs. So I will have to set up an internal DNS server and every time there's a dns change, I'll have to update both internal and public DNS servers?
and the reason I have to use public domain is for example apache virtual host, it reads domain name
I'd say internal dns is better than a hosts file on all the internal machines.
Also, I'm don't know what these web servers are hosting, but NOT putting them in a dmz separated from your internal hosts is relatively unheard of in a corporate environment anymore.
ok I guess I'll need to set up an internal DNS.
I would prefer putting them in DMZ but RV180 only allows 1 dmz host so i don't have choices.
