assigning switch ports to switch in cisco.
ahmadqayyum7
In the diagram below how will I assign switch ports to Switch 1?
Reza Sharifi
If you want the ports as access ports:
# interface fastethernet [interface number]
# switchport mode access
# switchport access vlan [vlan number]
If you want the ports as trunk ports:
# switchport mode trunk
# switchport trunk allowed vlan [vlan numbers]
one more thing. when configuring trunking mode will i give the same interface ranges on all switches?
Hi  @ahmadqayyum7 ,
When you configure an interface as a trunk, you can leave by default to allow the passage of all the vlan:
Switch(config)#interface f0/1
Switch(config-if)#switchport mode trunk
or select what vlan you will allow:
Switch(config-if)#switchport trunk allowed vlan <vlan range>
Obviously, the allowed vlan range must be the same at both ends of the link.
