Attempting to use Loopback /32 as NAT source for a dot1q sub-interface
Drew T.
I'm sure i've done this before, but for some reason it just doesn't seem to be working.
Our provider have allocated an extra subnet to us, that's being sent over a DHCP service (fibre ethernet service). I've associated a /32 from the allocated subnet to Loopback10. I can ping it from the outside world, and can reach the router without any issues, so the IP is definitely seen and working.
Sub-interface is on a dot1q VLAN and is currently working with a regular NAT setup, using the main IP from our provider.
Here's the configuration i'm attempting that does not seem to be working:
GigabitEthernet0/0.10
encapsulation dot1q 10
ip address 192.168.10.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip accounting output-packets
ip nat inside
no ip virtual-reassembly in
ip nat inside source list int10 interface Loopback10 overload
Loopback10
ip address 1.2.3.4 255.255.255.255
ip access-list extended int10
 permit ip 192.168.10.0 0.0.0.255 any
I have also attempted to try it with a NAT pool and route-map, but its not working (the loopback is a /30 and the nat pool won't accept a subnet smaller than a /30).
This is pretty urgent and i'm kinda scratching my head. Anyone able to offer a suggestion here?
I've tried a lot of searches and nothing seems to suggest it'll work as I want it to. Any traffic originating from VLAN10 simply has to have the IP of the Lo10 interface when going to the outside world.
Seb Rupik
int loop10
  ip nat outside
cheers,
Seb.
Julio E. Moisa
The ip nat outside should be configured under a phisycal or logical (sub-interface) interface but the problem here could be that the IP 1.2.3.4 is not being known on the other router, so you should create at least a static router, imagine this scenario:
ROUTER 1 ------ L3 Link ------ ROUTER2
ROUTER1
interface loopback 0
interface g0/0
description TO-ROUTER2
ip address 10.12.0.1 255.255.255.252
ip nat outside
no shutdown
interface g0/1
description TO-MY-NETWORKS
ip nat inside
no shutdown
ip access-list standard MY-NETS
permit 192.168.1.0 0.0.0.255
ip nat inside source list MY-NETS interface loopback0 overload
ip route 0.0.0.0 0.0.0.0 10.12.0.2 name INTERNET
ROUTER 2
Now, how R2 does not know about the R1's loopback, you must allow that communication so you need to create a method, the easy way is a static route.
ip route 1.2.3.4 255.255.255.255 10.12.0.2
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
