Authenticate Switch with Cisco ACS with SSH instead of Telnet
taufeeq taufeeq
Dear All,
I want to authenticate the switches in DMZ zone(Behind Firewall) against AAA server. Config used under line vty is mentioned. Unfortunately our security colleagues are asking me to use SSH instead of telnet as its not secure. Please help me with the SSH config of ACS. Am I lacking the understandability of telnet & AAA ??? please clarify my doubt.
line con 0
 session-timeout 5
 exec-timeout 5 0
 password 7 094F471A1A0A
 login authentication noauth
 transport preferred none
line vty 0 4
 session-timeout 5
 exec-timeout 5 0
 password 7 104D000A0618
 login authentication vty
 transport preferred telnet
 transport input telnet
Thanks in advance,
Taufeeq.
Mark Malone
if its just allowing ACS use ssh instead of telnet remove telnet from vty
no transport preferred telnet
no transport input telnet
change to transport input ssh & transport preferred ssh
You will need to have ssh enabled though aswell globally on the switch
ip ssh ver 2
ip domain-name x/x
ip ssh authentication-retries 3
ip ssh timeout 60
and generate your secure keys
crypto key generate rsa ----  use 1024 for ver2
check with show ip ssh
There is no "transport input ssh & transport preferred ssh" commands. only
   all    All protocols
   none  No protocols
   telnet  TCP/IP Telnet protocol
are available. I am having  (C3750-IPBASE-M), Version 12.2(35)SE5, switch. Please assist.
Thanks in Advance.
Hi you need a K9 image for ssh for crypto , it will need to be upgraded to support ssh
