Authentication Failure
DEENA VERAPPAN
Level 2
Level 2
Hi All, I'kinda stranded and maybe even stuck for a solution. I'm connected to my Cisco 3650 switch over the console port, when I try to enter enable mode I get an % Error in authentication.
cat3650>ena
I'd like to erase the configuration and start from scratch, but I need to get into enable mode to do that.
I've tried a hard boot, holding down the mode button and powering the switch, however when I load the ios from flash
switch: boot flash:xxx.bin
get the same problem.
Version: WS-C3650-48PS 16.3.5b
Deena
johnd2310
Level 11
Level 11
HI,
Have you tried going into rom mode and configuring the switch to ignore the startup configuration? You can use the procedure in the following url under the section "Recovering from a Lost or Forgotten Password":
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/system_management/configuration_guide/b_sm_3se_3650_cg/b_sm_3se_3650_cg_chapter_01111.html#task_1021182
**Please rate posts you find helpful**
