Auto-QOS Catalyst 4500
Can anyone tell me if it is better to use the auto qos on catalyst 4510R+E Sup7
thanks in advance
auto qos voip trust
SW-2960-POE <-------- Gi9/1 - Catalyst 4500  - Gi9/6 ---> BABX
interface GigabitEthernet9/1
 switchport trunk native vlan 100
 switchport mode trunk
 auto qos voip trust
 service-policy input AutoQos-VoIP-Input-Cos-Policy
 service-policy output AutoQos-VoIP-Output-Policy
interface GigabitEthernet9/6
 switchport access vlan 110
 switchport mode access
 logging event trunk-status
 auto qos voip trust
policy-map AutoQos-VoIP-Output-Policy
class AutoQos-VoIP-Bearer-QosGroup
   set dscp ef
   set cos 5
   priority
   police cir percent 33
class AutoQos-VoIP-Control-QosGroup26
   set dscp af31
   set cos 3
   bandwidth remaining percent 5
class AutoQos-VoIP-Control-QosGroup24
   set dscp cs3
   set cos 3
class class-default
dbl
Policy-map AutoQos-VoIP-Input-Cos-Policy
 class AutoQos-VoIP-Bearer-Cos
   set qos-group 46
 class AutoQos-VoIP-Control-Cos
   set qos-group 24
policy-map AutoQos-VoIP-Input-Dscp-Policy
 class AutoQos-VoIP-Bearer-Dscp
   set qos-group 46
 class AutoQos-VoIP-Control-Dscp26
   set qos-group 26
 class AutoQos-VoIP-Control-Dscp24
   set qos-group 24
class-map match-all AutoQos-VoIP-Control-Dscp26
match dscp af31
class-map match-all AutoQos-VoIP-Control-Dscp24
match dscp cs3
class-map match-all AutoQos-VoIP-Bearer-Cos
match cos 5
class-map match-all AutoQos-VoIP-Bearer-QosGroup
match qos-group 46
class-map match-all AutoQos-VoIP-Bearer-Dscp
match dscp ef
   set dscp cs3
   set cos 3
match qos-group 46
match dscp ef
Rajeshkumar Gatti
Autoqos is a macro based config which will build the config for you. If the configs match up with the Qos designs you have in place then certainly it can be used to make deployments easier.
-Raj
