auto-sync standard
Ahmede
In 4507 with two SUP's.. What does this command do? Here's what Cisco has to say about that command
"During normal operation, the startup-config, boot variables,
config-registers, and VLAN database configuration are synchronized by
default between the two supervisor engines. In a switchover, the new
active supervisor engine uses the current configuration.
To manually synchronize the configurations used by the two supervisor
engines use auto-sync standard"
But I still do not understand what does that mean and what will it do.. If the config's and sync by default, why do we need manaul sysnc?
Thanks in advance..
smalkeric
Level 6
Level 6
Follow these guidelines and restrictions when creating and modifying VLANs in your network:
Before creating a VLAN, put the Catalyst 4500 series switch in VTP server mode or VTP transparent mode. If the Catalyst 4500 series switch is a VTP server, you must define a VTP domain. For information on configuring VTP, see "Understanding and Configuring VTP."
The Cisco IOS end command is not supported in VLAN database mode.
You cannot use Ctrl-Z to exit VLAN database mode.
This URL should help you:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a0080731495.html
Sayyed.Akhtar
This enables automatic synchronization of the active Supervisor card configuration to standby Sup.
