Connecting a Hawking HOWABN1 Access Point to Cisco 3560 Switch
mconway
I'm having issues connection a Hawking access point to a Cisco 3560 switch.
I am unable to ping the access point from the switch CLI.
The interface config looks like this: (interface where AP is connected to)
interface GigabitEthernet0/15
switchport mode trunk
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
I also could use some help in designing the topology.  DHCP / VLAN
Currently I have the AP acting as a DHCP Server.   There is also a Windows DHCP Server on the LAN
AP is 10.0.1.240 / 24
Gateway Address is 10.0.1.254 / 24 which is the SVI for VLAN 15
Ideally I would like to set this AP up as follows:
Main SSID would be for LAN and Internet Access
ESSID would by for just Internet Access (Public WiFi) this unit supports VLAN IDs for this.
juan.elias.gt
Hi, your problem is in the native-vlan, for defect HOWABN1 set default vlan as administrative vlan. Talking about another topic i have a doudt, what´s amount of bandwith should have during a file transfer? I have troubles with it.
