automated device provisioning (reset)?
For a lab setting, is there a way to automatically reset all devices to default/destired settings, no matter what has been done, including changing password, misconfigured console/aux/vty lines, deleted image file, disabled ports etc...
For example, I set up the lab and access it remotely through an access server. How can I reset it to preconfigured-default if I misconfigured something to lock myself out?
John Blakley
Take a look at the rollback feature and see if that will help you:
http://www.cisco.com/en/US/docs/ios-xml/ios/config-mgmt/configuration/xe-3s/asr1000/cm-config-rollback.html
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
