Automatic VLAN reverting/changing
Praveen SVN
Hello All,
I just want to know whether we can assign time stamp for a port to be in the particular VLAN. Like port should be reverted to another VLAN after particular time. Is there any feasibility for this? Can anyone help me.
Praveen.
Mark Malone
You could do that but you would need an EEM script to initiate it and base it against a timed acl or the clock on the router , standard cli cant do this , I would move this post to the EEM section of the forum , you may get a better response , if you search as well you may find someone has already built something similar you could tweak
or if the system has dual links you could set 2 ips on it and connect them both to the switch and then use a time based acl so only 1 can work at certain times and the other works at another time , put the links into 2 diff vlans
