Automatically Nexus Backup using FTP
pablo.arcelcr
Level 3
Level 3
I have a nexus 9000 how can I automatically do a backup using the ftp.
This is the ftp:
copy running-config ftp://10.154.5.21/CRRHR-CORE-PRI.txt
But I would to do that automatically
Reza Sharifi
The switch can't do automatically. If you have a management software like SolarWinds, it can backup the config for you daily, nightly or when ever you like.  The other option would be to write a script and have it login trigger the command and than logout.
But in catalyst we can do it autamically, is there any option similar as catalyst using FTP in Nexus?
