Automating Backup of configuration Cisco Nexus 5 and 7k's
thekid1970
Hello
I need some help regarding automating the backup of configuration of Nexus 5 and 7k's. What are people doing regarding this situation?
Thoughts?
14 Replies 14
Jerry Ye
You can try DCNM or Ciscoworks LMS.
jerry
Jerry,
I did do some reading on DCNM.... I was just wondering if you could have place some scripts to go to a tftp,scp etc to a server? I know in IOS on cisco routers/switches you can setup kron jobs/archive to do this... it appears nexus OS dont have those commands.
Any feedback would be appreciated.
John
Kron is not available in NXOS, you try EEM on the 7K (EEM is not available on the 5K). Here are some of the example
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_eem_events_and_examples.html
HTH,
jerry
Jerry,
thanks with your quick response. so with that said, if eem is not available on the 5k's would you just go ahead and configure a server with dcnm on it and go that route?
i do have 2 7k's and 6 5k's in our data center.
Jerry, thanks for all your help. i will go DCNM way.
I use cacti, with the router configs plugin. The config needed a bit of tweaking to recognise the nexus itself, but once that was done, and a little alteration to the default script, all it has to do is a
copy run tftp://%SERVER%/%FILE% vrf management vdc-all
The cacti plugin then replaces %SERVER% and %FILE% with the appropriate values (On detecting NX-OS base context), and away it runs.
H
Hamish,
i appreciate your input. since i have a bunch of NX-OS devices, i will just go ahead and utilize DCNM.
edwardzeng
You don't need DCNM to do this job.
you can config the schedule to do that for you.
============= Example =========
scheduler job name Backup-Weekly
copy running-config tftp://192.168.x.y/$(SWITCHNAME)-conf.$(TIMESTAMP) vrf management vdc-all
scheduler schedule name Backup-Weekly
  time weekly 06:23:50
Then after that you can run this command to verify it.
show scheduler schedule
After that you can check with this command too:
sh scheduler logfile
`copy running-config tftp://192.168.x.y/hostname-conf.2014-09-19-14.50.00 vrf management vdc-all `
Connection to Server Established.
[                         ]         0.50KBTrying to connect to tftp server......
[######                   ]        24.50KB
[############             ]        48.50KB
[##################       ]        68.50KB
TFTP put operation was successful
Copy complete.
there is no scheduler on my n5k:
(config)# sch?
% Invalid command at '^' marker.
Did you enable feature scheduler ?
no such feature in 5.2(1)
Does anyone know if there is a way to activate the scheduler when doing a config save ? With the archive feature you have this option (but archive doesn't support scp)
Thx
ninel
I had the same problem and solve it with a alias and a EEM
We have Nexus9000 with NXOS version 9.3
conf t
cli alias name wr copy running-config startup-config ; event manager run ARCHIVE_CONFIG
event manager environment new_archive_file "$(SWITCHNAME)-$(TIMESTAMP).cfg"
event manager applet ARCHIVE_CONFIG
  action 10 syslog msg Archiving running-config to FTP server.
  action 20 cli copy running-config ftp://<USER>:<PASSWORD>@10.1.1.1/FTP_PATH/$new_archive_file
Now each time you enter 'wr' it will save the config and also make a new backup, similar to IOS archive configuration
It will also generate a new unique filename for each file based on device name and timestamp.
Hope this will help others as well...
Cheers!
