12-09-2011 08:48 AM - edited 03-07-2019 03:49 AM
Hello all,
Has Cisco changed something on the way autonegotiation works in the new IOS ?? I feel like a dummie: i hooked up
two switches with a cross cable, configured one port in static 100 full duplex, the other one in autonegotiation and the
autoneg one negotiates to full duplex ? doh ? shouldn't it fallback to half duplex ? whats even more: if i change the static one to
half duplex, the autoneg one follows to half duplex ? seems like they are still both running autoneg
Switch A: 15.0(1)SE1, WS-C3750V2-48PS
Switch B: 12.2(53)SE, WS-C3750V2-48PS
Between the switches on port fa1/0/48 a CROSSED cable.
Port config on A:
interface FastEthernet1/0/48
no switchport
ip address 1.1.1.2 255.255.255.0
no mdix auto
no cdp enable
end
Por config on B:
no switchport
ip add 1.1.1.1 255.255.255.0
carrier-delay msec 0
speed 100
duplex full
no mdix auto
no cdp enable
exit
Result:
SWITCH A/ Fa1/0/48 routed a-full a-100 10/100BaseTX
SWITCH B: Fa1/0/48 routed full 100 10/100BaseTX
Aren't there any certainties any more.....
12-09-2011 09:04 AM
Ha...added "power inline never" to both ports and guess what:
Fa1/0/48 routed a-half a-100 10/100BaseTX
Since when does power influence autonegotiation ??
12-09-2011 09:43 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Pre-standard Cisco PoE also uses FLP for power detection. This FLP power detection method might be "confused" as speed/duplex autonegotiation.
12-09-2011 09:39 AM
I was able to test this with 2 3750-E switches. In this scenario I am using port 1/0/48 on both switches. The switches are called switch A and switch B
When I set the duplex to full and speed to 100 on switch B switch A's interface shows 100 Full
Here is the config and show command for switch B
Switch-C#sh run in gi1/0/48
Building configuration...
Current configuration : 63 bytes
interface GigabitEthernet1/0/48
speed 100
duplex full
end
Switch-B#sh int gi1/0/48
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:08, output 00:00:00, output hang never
Switch A config and show command
Switch-A#sh run int gi1/0/48
spanning-tree portfast
end
Switch-A#
Switch-A#sh interfaces gi1/0/48
When auto-negotiation is disabled on one switchport the switch at the other end of the link can use the Parallel detection function to determine the speed. Put simply the switch does not negotiate the speed with the other switch but it can still work it out.
However what it cannot work out without auto-negotiation is the duplex. Now as far as i know 10/100 ethernet interfaces default to half-duplex and gigabit interfaces default to full duplex. So you could interprete this to mean the port would set itself to 100 Full because of it's default setting is gigabit.
Follow this discussion for further explanation:
https://supportforums.cisco.com/thread/2018138
Hope that helps.
--Sweta
Please rate useful posts.
12-09-2011 09:46 AM
No sure about 3750v2 but Catalyst 3560v2 behave differently: if you configure both speed and duplex statically on a port, the autonegotiation will not be deactivated but will advertise only a single capability including the preconfigured speed and duplex .This is actually more intuitive and natural behavior but obviously, this is not supported on older switches. Probably it depends on the PHY controllers used in Catalyst switches and they seem to be different between various Catalyst platforms.
This all makes the autonegotiation and all exceptions around it a most cumbersome topic - so my recommendation usually is that either both ends of a link are set to autonegotiation with no static settings, or both speed and duplex are set statically on both link ends. The behavior of autonegotiation on Catalyst switches is not well documented and is obviously platform and version dependent, making it quite hard to remember.
-Sweta
