autonegotiation
kaustubhchavan
If switch's port having capability of 10/100 mbps & set to autonegotiated & other device connected to tht port support to both Half & full duplex then which one will it choose ?
glen.grant
If both ends set to autonegotiate it will usually negotiate to the fastest speed and full duplex. If you have auto on one end and the other end is hardcoded then the auto end will come in at half duplex and thus you have a speed/duplex mismatch . Both ends must match setting wise.
