Aux port to console port
anitachoi3
Hi expert,
I would like to connect two equipment (Cat 4506 and router 2901) together via AUX and Console port. The path is following
PC workstation ---> Internet ---> Cat 4506 --> vai AUX port of Cat 4506 to access 2901's console port.
Is it possible? If yes, how to access 2901 after I login to Cat 4506? furthermore, there is no ip access on router 2901.
rdge
Anita
TIMOTHY BENKULA
What you're wanting to do is called reverse telnet. Check out this site:
http://www.tek-tips.com/faqs.cfm?fid=1312
TIMOTHY BENKULA
