Issue downloading cisco IOS using TFTP
kamrannaseem
Hi All,
I have installed Solarwind TFTP on my windows xp machine and trying to downgrade my cisco switch image to c3750-ipbasek9-tar.122-35.SE5.tar
the current version is "flash:/c3750-ipbasek9-mz.122-55.SE5/c3750-ipbasek9-mz.122-55.SE5.bin"
Gives me the following errorrs when i try to download the image.
Could not buffer tarfile...using multiple downloads
examining image...
%Error opening tftp://128.1.97.55/c3750-ipbasek9-tar.122-35.SE5.tar (Timed out)
%Error opening flash:update/info (No such file or directory)
ERROR: Image is not a valid IOS image archive.
any help will be much appriciated.
Many thanks.
2 Accepted Solutions
ashirkar
Level 7
Level 7
Hi Kamran,
first please check your TFTP server is reachable from your switch.If yes ? then check your flash memory space using "dir flash:"  command.If you have sufficient flash: memory for new image then use
"archive download-sw /overwrite tftp://128.1.97.55/c3750-ipbasek9-tar.122-35.SE5.tar"
to upload your imange to switch.
There is difference procedure to upload .bin and .tar extension file in switch flash:
Like for .bin
it just simple steps type
"copy tftp flash:" and then just hit enter button, it will ask you for tftp server ip and Image detail.make sure you use .bin extension
Here is document available on cisco.com for
Upgrading Software Images on Catalyst 3550 Series Switches Using the Command Line Interface
Hope that help
Ashish
Community Manager-NI
Error: system number 1 does not support the same feature set.
This means the current feature set is not the same as the feature set you are downgrading to.
Kindly use the "/allow-feature-upgrade".
7 Replies 7
TIMOTHY BENKULA
Are you using the tar command or the copy command?
ashirkar
Level 7
Level 7
Hi Kamran,
Like for .bin
Hope that help
Ashish
Hi Ashish,
It seems that it copies the image but gives couple of errors at the end :
Switch#$overwrite tftp://128.1.97.57/c3750-ipbasek9-tar.122-35.SE5.tar
Loading c3750-ipbasek9-tar.122-35.SE5.tar from 128.1.97.57 (via Vlan1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 10434560 bytes]
examining image...
extracting info (106 bytes)
extracting c3750-ipbasek9-mz.122-35.SE5/info (614 bytes)
Stacking Version Number: 1.34
System Type:             0x00000000
  Ios Image File Size:   0x00767200
  Total Image File Size: 0x009F3A00
  Minimum Dram required: 0x08000000
  Image Suffix:          ipbasek9-122-35.SE5
  Image Directory:       c3750-ipbasek9-mz.122-35.SE5
  Image Name:            c3750-ipbasek9-mz.122-35.SE5.bin
  Image Feature:         IP|LAYER_3|SSH|3DES|MIN_DRAM_MEG=128
Error: The image in the archive which would be used to upgrade
many thanks.
kamran.
Hi Leo,
Thank you ever so much ... it is working now. !!!!
many many thanks.
Kamran.
Cheers Kamran,
Thanks Leo for helping community users
Ashish
Thanks Ashish for your time.
