Avaya Phones, Cisco Switches and QoS (MPLS network in between)
l.mourits
Level 5
Level 5
All,
I am implementing QoS on our MPLS network. Our environment exists of a mix of Cisco 3750 and 3560 switches. The IPT system is Avaya CM with Avaya phones.
The WAN network is a MPLS network.
Ports are configured for access and voice vlan (no trunking), one vlan for voice, one for data (vlan 1 is disabled).
We like to trust dscp settings from the Avaya phone (pretty simple to figure that out, just auto qos voip trust). Testing it I found the Avaya phones leaves any markings on the data vlan untouched.
We are planning on setting the dscp marks for other traffic then Voice on our packetshapers (that are in between the router and te switch uplink to the router). That all works great.
Upon failure of the packetshaper I need all traffic other then voice to be marked as AF21 instead of BE, and I am looking for the easiest way to do this. preferably without using access-lists that hold IP info (as I like to standardize my configs as much as possible).
So, i am looking to trust dscp mapping on the access ports of each switch (autoqos trust dscp, easy) and then have all traffic coming into the data vlan marked with dscp 18 (AF21) before it leaves the switch. All trunks will be configured to trust dscp as well.
With the dat vlan getting dscp marked as AF21, then remarking the traffic on our packetshapers, I would have all marking set correctly before it enters the ploicymap on the CPE of the MPLS provider, and if the Packetshaper fails I would still have the AF21 and Voice markings. that way I try to avoid all data traffic to end up in the BE class upon packetshaper failure.
Can anyone tell me the easiest way to put a default dscp marking on ingress traffic in the data vlan?
Thanks in advance,
Leo
Leo
Yep, clever bloke Andy, i worked with him on a project in the UK.
I think you're right in what you say. The service-policy should apply all the correct markings and with the "permit ip any any" it is generic enough to be applied throughout your network.
Good luck with the deployment, let me know how it goes.
Jon
10 Replies 10
Jon Marshall
Leo
You would normally use class maps and acl's to match the traffic and then set your DSCP value.
However you say you don't want to use this. There is the option to use a DSCP-to-DSCP mutation map. This is done on a per port basis and allows you to change the incoming DSCP value to one of your choosing -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swqos.html#wp1031921
Have never used this before but does this sound like what you need ? If so i have a couple of 3550 switches to hand and i could knock up a quick test.
One other thing though. You say you want to keep standard config. Using class-map with acl would be standard though because the acl would be the same on each data port. Or perhaps i am misunderstanding ?
Jon
Jon,
(nice to see one of the best on the forum reply ;-))
What I mean with trying to standardize configs is to standardize configs throughout the globe. My company has many sites, all with their own subnets, which is why I wanted to avoid the ACLs as they would have to include the IP info ;-)
What I am currently testing is to see if I can actually mix trust and service-policy on the interfaces. The Avaya phones are configured to send the correct dscp markings, and by matching and reclassifying the traffic I think it could work.
Let me know what you think of the following:
ip access-list extended vlan-data
permit ip any any
class-map match-all vlan-voice-rdp
match ip dscp ef
class-map match-all vlan-voice-signaling
match ip dscp af31
class-map match-all vlan-data
match access-group name vlan-data
policy-map ipphone
class vlan-voice-rdp
set ip dscp 46
police 128000 8000 exceed-action drop
class vlan-voice-signaling
set ip dscp 26
police 32000 8000 exceed-action policed-dscp-transmit
class vlan-data
set ip dscp 18
police 800000 8000 exceed-action policed-dscp-transmit
class class-default
set ip dscp 0
police 5000000 8000 exceed-action policed-dscp-transmit
interface x/y/z
switchport access vlan
switchport mode access
switchport nonegotiate
switchport voice vlan
no logging event link-status
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
priority-queue out
no snmp trap link-status
auto qos voip trust
storm-control broadcast level 50.00
storm-control multicast level 50.00
storm-control unicast level 99.00
storm-control action trap
spanning-tree portfast
service-policy input ipphone
exit
I get the impression while testing that it actually works, allthough there seem to be a cosmetic issue, where the access-list and policy-maps show no matches. But if that is the only downside, I'm okay with it. I did see traffic ending up in AF21 now, which was not the case before I entered this.
Thanks in advance,
Leo
Leo
"(nice to see one of the best on the forum reply ;-))" - appreciate the compliment altho you may want to wait until we have finished this thread :-)
Funnily enough i was thinking of using "permit ip any any" for data when i was talking about standardising to "mop" up the non VOIP traffic which is exactly what you have done. As long as it is in the right order in your policy-map then it will be fine altho you realise nothing will match class-default unless you have non-IP traffic on the port.
You need to have a read of this thread as it was one i was involved in recently about mixing trust state and service-policy on the same interface. Andy Butterworth seems to be suggesting they cannot be used together and the documentation backs this up altho i'm not sure how the "auto qos voip trust" affects this. If you are sure packets are getting marked properly then perhaps the auto qos setting behaves differently.
Also there is an issue with 3560/3750 in that they do not keep counters for QOS/ACL's switched in hardware. Next best command is
sh mls qos interface statistics.
Jon
Jon,
Can you send the link to the thread you mentioned?
Leo
Please can you advise how you are using voice vlan with avaya phones without using trunking and native vlans like we have setup. Do you need to make adjustments to the 46xxxsettings.txt file or are you using LLDP?
Hi Jon,
I think the link says it all, one can not use autoqos trust and service-policy at the same time. I think Andy Butterworth is correct in his assumption it has never worked but still showed in previous version. I am running a previous version and saw the trust stayed in but as soon as I tried to configure it to trust dscp instead of the default cos, it removed the service-policy.
That said, I think the service-policy I listed out should do the trick, right? I agree the default-class should not be hit unless for layer2 traffic. Other then that comment, do you agree the service-policy is correct?
Thanks for your replies so far :-)
Leo
Leo
Jon
Ok then Jon, I woud have to say thank you and Andy. Gave you guys both proper credit ;-)
Only thing I want to look at in addition is to see if I can match on voice vlan for the voice classes, next to the match on the dscp markings, as that would ensure data vlan would not respect any markings.
I'll play with it, I marked the thread as resolved as I believe the thread contains good answers and a resolution. Once I completed my config, I'll post it back to this thread to share with the community.
Thanks again,
Leo
Jon,
I have tested the service-policy in the test environment and it does exactly what it needs to do. I ended up with the following config.
permit ip any any
ip access-list extended vlan-voice
permit ip
match ip dscp ef
match access-group name vlan-voice
policy-map ipphone
set dscp ef
set dscp af31
class vlan-data
set dscp af21
interface for PBX system and WAN routers
mls qos trust dscp
auto qos voip trust
interface for IPphone+PC
Current config on those switches.
mls qos map policed-dscp 0 24 to 8
mls qos map cos-dscp 0 8 16 24 34 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
IPphone+PC interfaces
priority-queue out
mls qos trust dscp
auto qos voip trust
What would be the recommended steps for changing this into the dscp markings?
Thanks in advance.
Leo
