Ayuda para configurar uBR10000
frajvep
Buenas noches.
Para no hacerla de emocion les pido de sus ayuda, acaban de comprar un UBR10000, y me pusieron la tarea de configurarlo y lo unico que me dieron es el: show running-config del que ya esta trabajando.
AQUI INICIO CON MI PRUEBA DE CONFIGURACION
% Please answer 'yes' or 'no'.
Would you like to enter the initial configuration dialog? [yes/no]: yes
At any point you may enter a question mark '?' for help.
Use ctrl-c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.
Basic management setup configures only enough connectivity
for management of the system, extended setup will ask you
to configure each interface on the system
Would you like to enter basic management setup? [yes/no]: yes
Configuring global parameters:
  Enter host name [Router]: Acaco_3.0
  The enable secret is a password used to protect access to
  privileged EXEC and configuration modes. This password, after
  entered, becomes encrypted in the configuration.
  Enter enable secret: xxxxx
  The enable password is used when you do not specify an
  enable secret password, with some older software versions, and
  some boot images.
  Enter enable password: xxxxxx
  The virtual terminal password is used to protect
  access to the router over a network interface.
  Enter virtual terminal password: xxxxxx
  Configure SNMP Network Management? [yes]: yes
    Community string [public]: snmp-server community public RO
Current interface summary
Any interface listed with OK? value "NO" does not have a valid configuration
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0/0      unassigned      NO  unset  up                    down
Enter interface name used to connect to the
management network from the above interface summary: FastEthernet0/0/0
Configuring interface FastEthernet0/0/0:
  Use the 100 Base-TX (RJ-45) connector? [yes]: yes
  Operate in full-duplex mode? [no]: yes
  Configure IP on this interface? [yes]: yes
    IP address for this interface: 193.168.70.2
    Subnet mask for this interface [255.255.255.0] : 255.255.255.0
    Class C network is 193.168.70.0, 24 subnet bits; mask is /24
The following configuration command script was created:
hostname Acaco_3.0
enable secret 5 $1$qa3O$B6.u7/nYia7/adwBKV023.
enable password xxxxx
line vty 0 4
password xxxxxx
snmp-server community snmp-server community public RO
no ip routing
no shutdown
media-type 100BaseX
full-duplex
ip address 193.168.70.2 255.255.255.0
end
[0] Go to the IOS command prompt without saving this config.
[1] Return back to the setup without saving this config.
[2] Save this configuration to nvram and exit.
Enter your selection [2]: 2
% Invalid input detected at '^' marker.
Building configuration...
Use the enabled mode 'configure' command to modify this configuration.
*Mar 14 01:23:35.671: CM file (ivfs:/ubr10k4-k9p6u2-m_matrix.cm) is not readable, using internal matrix table
*Mar 14 01:23:37.123: %C10K_TOASTER-6-STARTLOAD: Downloading Microcode: file=system:pxf/c10k-cr4-ucode.101.0.0.0, version=101.0.0.0, description=Nightly Build Software created Sat 26-May-12 02:29
Press RETURN to get started!
*Mar 14 01:23:41.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0/0, changed state to up
*Mar 14 01:23:41.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Mar 14 01:23:41.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Mar 14 01:23:41.847: %LINK-3-UPDOWN: Interface FastEthernet0/0/0, changed state to up
*Mar 14 01:23:42.087: %RED-5-REDCHANGE: PRE B now not present(0x0 => 0x1031)
*Mar 14 01:23:42.243:  Unexpected Timer 7 on RP
*Mar 14 01:23:42.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/0, changed state to down
*Mar 14 01:23:44.871: %FILESYS-5-CFLASH: Compact flash card inserted into local PRE (PRE slot A), slot0
*Mar 14 01:25:31.603: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:27:31.627: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:29:31.651: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:31:31.675: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:33:31.699: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:35:31.723: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:37:31.747: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:39:31.771: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:41:31.795: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:43:31.819: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:45:31.843: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:47:31.867: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:49:31.891: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:51:31.915: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:53:31.939: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:55:31.963: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:57:31.987: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 01:59:32.011: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:01:32.035: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:03:32.059: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:05:32.083: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:07:32.107: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:09:32.131: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:11:32.155: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:13:32.179: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:15:32.203: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:17:32.227: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:19:32.251: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:21:32.275: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:23:32.299: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:25:32.323: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:27:32.347: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:29:32.371: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:31:32.395: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:33:32.419: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:35:32.443: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:37:32.467: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:39:32.491: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:41:32.515: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:43:32.539: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:45:32.563: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:47:32.587: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:49:32.611: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:51:32.635: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:53:32.659: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:55:32.683: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:57:32.707: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 02:59:32.731: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:01:32.755: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:03:32.779: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:05:32.803: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:07:32.827: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:09:32.851: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:11:32.875: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:13:32.899: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:15:32.923: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:17:32.947: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:19:32.971: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:21:32.995: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:23:33.019: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:25:33.043: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:27:33.067: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:29:33.091: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:31:33.115: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:33:33.139: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:35:33.163: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:37:33.187: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:39:33.211: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:41:33.235: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:43:33.259: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:45:33.283: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:47:33.307: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:49:33.331: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:51:33.355: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:53:33.379: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:55:33.403: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:57:33.427: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 03:59:33.451: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:01:33.475: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:03:33.499: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:05:33.523: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:07:33.547: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:09:33.571: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:11:33.595: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:13:33.619: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:15:33.643: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:17:33.667: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:19:33.691: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:21:33.715: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:23:33.739: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:25:33.763: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:27:33.787: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:29:33.811: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:31:33.835: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:33:33.859: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:35:33.883: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:37:33.907: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:39:33.931: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:41:33.955: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:43:33.979: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:45:34.003: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:47:34.027: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:49:34.051: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:51:34.075: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:53:34.099: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:55:34.123: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:55:58.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/0, changed state to up
*Mar 14 04:57:34.147: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 04:59:34.171: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:01:34.195: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:03:34.219: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:05:34.243: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:07:34.267: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:09:34.291: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:11:34.315: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:13:34.339: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:15:34.363: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:17:34.387: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:19:34.411: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:21:34.435: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:23:34.459: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:25:34.482: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:27:34.506: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:29:34.530: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:31:34.554: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:33:34.578: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:35:34.602: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:37:34.626: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:39:34.650: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:41:34.674: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:43:34.698: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:45:34.722: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:47:34.746: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:49:34.770: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:51:34.794: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:53:34.818: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:55:34.842: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:57:34.866: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 05:59:34.890: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:01:34.914: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:03:34.938: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:05:34.962: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:07:34.986: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:09:35.010: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:11:35.034: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:13:35.058: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:15:35.082: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:17:35.106: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:19:35.130: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:21:35.154: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:23:35.178: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:25:35.202: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:27:35.226: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:29:35.250: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:31:35.274: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:33:35.298: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:35:35.322: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:37:35.346: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:39:35.370: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:41:35.394: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:43:35.418: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:45:35.442: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:47:35.466: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:49:35.490: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:51:35.514: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:53:35.538: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:55:35.562: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:57:35.586: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 06:59:35.610: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:01:35.634: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:03:35.658: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:05:35.682: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:07:35.706: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:09:35.730: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:11:35.754: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:13:35.778: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:15:35.802: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:17:35.826: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:19:35.850: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:21:35.874: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:23:35.898: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:25:35.922: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:27:35.946: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:29:35.970: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:31:35.994: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:33:36.018: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:35:36.042: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:37:36.066: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:39:36.090: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:41:36.114: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:43:36.138: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:45:36.162: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:47:36.186: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:49:36.210: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:51:36.234: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:53:36.258: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:55:36.282: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:57:36.306: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 07:59:36.330: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:01:36.354: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:03:36.378: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:05:36.410: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:07:36.434: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:09:36.458: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:11:36.482: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:13:36.506: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:15:36.530: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:17:36.554: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:19:36.578: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:21:36.602: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:23:36.626: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:25:36.650: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:27:36.674: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:29:36.698: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:31:36.722: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:33:36.746: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:35:36.770: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:37:36.794: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:39:36.818: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:41:36.842: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:43:36.866: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:45:36.890: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:47:36.914: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:49:36.938: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:51:36.962: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:53:36.986: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:55:37.010: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:57:37.034: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 08:59:37.058: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:01:37.082: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:03:37.106: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:05:37.130: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:07:37.154: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:09:37.178: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:11:37.202: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:13:37.226: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:15:37.250: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:17:37.274: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:19:37.298: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:21:37.322: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:23:37.346: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:25:37.370: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:27:37.393: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:29:37.417: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:31:37.441: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:33:37.465: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:35:37.489: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:37:37.513: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:39:37.537: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:41:37.561: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:43:37.585: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:45:37.609: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:47:37.633: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:49:37.657: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:51:37.681: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:53:37.705: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:55:37.729: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:57:37.753: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 09:59:37.777: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:01:37.801: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:03:37.825: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:05:37.849: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:07:37.873: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:09:37.897: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:11:37.921: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:13:37.945: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:15:37.969: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:17:37.993: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:19:38.017: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:21:38.041: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:23:38.065: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:25:38.089: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:27:38.113: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:29:38.137: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:31:38.161: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:33:38.185: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:35:38.209: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:37:38.233: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:39:38.257: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:41:38.281: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:43:38.305: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 10:45:38.329: %UBR10KTCC-1-NOTCC: No working TCC card available in the system
*Mar 14 14:24:43.020: %IPCOIR-3-CARD_GET_VERSION_RESPONSE: Unsolicited response from slot 1/0, oir_state = empty
*Mar 14 14:24:47.712: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable8/0/2, changed state to down
*Mar 14 14:24:47.712: %SNMP-5-LINK_DOWN: LinkDown:Interface Cable8/0/2 changed state to down
*Mar 14 14:24:47.712: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable8/0/3, changed state to down
*Mar 14 14:24:47.712: %SNMP-5-LINK_DOWN: LinkDown:Interface Cable8/0/3 changed state to down
*Mar 14 14:24:47.712: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable8/0/4, changed state to down
*Mar 14 14:24:48.512: %LINEPROTO-5-UPDOWN: Line protocol on Interface HTDP0/0/1, changed state to up
*Mar 14 14:24:48.664: %IPCOIR-5-CARD_DETECTED: Card type ubr10k-clc-mc2020v (0x641) in slot 8/1
*Mar 14 14:24:48.864: Card 17 is using crane FT
*Mar 14 14:24:53.400: %IPCOIR-5-CARD_DETECTED: Card type 4jacket-1 (0x564) in slot 1/0
*Mar 14 14:24:53.400: %IPCOIR-5-CARD_LOADING: Loading card in slot 1/0 sw version 1.1 code MD5 3579087BE4B3EFD0D71023C35C1C958E fpga MD5 89C8DD3DCD939BDD43DB19D514416137
*Mar 14 14:25:02.376: %C10K-5-LC_NOTICE: Slot[2/1] Line-card Image Downloaded...Booting...
*Mar 14 14:25:02.648: %C10K-5-LC_NOTICE: Slot[2/0] 4jacket-1 Image Downloaded...Booting...
*Mar 14 14:25:08.612: %IPCOIR-5-CARD_DETECTED: Card type 2cable-dtcc (0x5B0) in slot 2/1
*Mar 14 14:25:08.684: %UBR10KTCC-6-CHG_CLK_REF: Clock reference source set to Internal for DTCC card 2/1 by process Plugin Start
*Mar 14 14:25:09.100: %UBR10KTCC-5-ACTIVE_TCC: DTCC card 2/1 is active with Internal as clock reference
*Mar 14 14:25:09.100: %UBR10KTCC-6-CHG_CLK_REF: Clock reference source set to Internal for DTCC card 2/1 by process Card Config
*Mar 14 14:25:09.104: %IPCOIR-2-CARD_UP_DOWN: Card in slot 2/1 is up.  Notifying 2cable-dtcc driver.
*Mar 14 14:25:09.520: %UBR10KTCC-5-DTISLOT: DTCC slot 2/1: card role changed to Active
*Mar 14 14:25:16.064: %IPCOIR-5-CARD_DETECTED: Card type 4jacket-1 (0x564) in slot 1/0
*Mar 14 14:25:18.876: %IPCOIR-2-CARD_UP_DOWN: Card in slot 1/0 is up.  Notifying 4jacket-1 driver.
*Mar 14 14:25:19.696: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/0, changed state to down
*Mar 14 14:25:19.700: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down
*Mar 14 14:25:19.704: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down
*Mar 14 14:25:19.708: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
*Mar 14 14:25:19.712: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/4, changed state to down
*Mar 14 14:25:33.528: %SPA_OIR-6-ONLINECARD: SPA (5xGE SPA) online in bay 1/0
*Mar 14 14:25:34.008: %C10KSPAGE-3-SFP_MISSING: Interface GigabitEthernet1/0/0, Gigabit ethernet module (SFP) missing
*Mar 14 14:25:34.008: Failed to assert C10K Gigabit Ethernet GBIC missing alarm for GigabitEthernet1/0/0
*Mar 14 14:25:35.640: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/0, changed state to up
*Mar 14 14:25:36.640: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/0, changed state to up
Acaco_3.0>C!▒*Ɂ14 14:27:21.484: %IPCOIR-5-CARD_DETECTED: Card type ubr10k-clc-mc2020v (0x641) in slot 8/1
SLOT 8/1: *Mar  1 00:00:53.403: %SYS-5-RESTART: System restarted --
Cisco IOS Software, 10000 Software (UBR10KG4CLC-LCK8-M), Version 12.2(33)SCF3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 04-Jun-12 16:04 by prod_rel_team
*Mar 14 14:27:22.196: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/1/0 changed state to up
*Mar 14 14:27:22.196: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/1/1 changed state to up
*Mar 14 14:27:22.196: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/1/2 changed state to up
*Mar 14 14:27:22.196: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/1/3 changed state to up
*Mar 14 14:27:22.196: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/1/4 changed state to up
*Mar 14 14:27:22.196: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U0, changed state to down
*Mar 14 14:27:22.196: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U1, changed state to down
*Mar 14 14:27:22.196: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U2, changed state to down
*Mar 14 14:27:22.196: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U3, changed state to down
*Mar 14 14:27:22.196: %UBR10000-5-UPDOWN: Interface Cable8/1/1 U0, changed state to down
*Mar 14 14:27:23.476: %IPCOIR-5-CARD_DETECTED: Card type ubr10k-clc-mc2020v (0x641) in slot 8/0
SLOT 8/0: *Mar  1 00:00:53.503: %SYS-5-RESTART: System restarted --
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U0, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U1, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U2, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U3, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U0, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U1, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U2, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U3, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/2 U0, changed state to down
*Mar 14 14:27:23.744: %UBR10000-5-UPDOWN: Interface Cable8/0/2 U1, changed state to down
SLOT 8/1: *Mar  1 00:00:53.559: %IPCGRP-6-UCODEVER: Reported microcode version, 1338851047.
SLOT 8/1: Mar 14 14:27:21.524: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U0, changed state to administratively down
SLOT 8/1: Mar 14 14:27:21.524: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U1, changed state to administratively down
SLOT 8/1: Mar 14 14:27:21.524: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U2, changed state to administratively down
SLOT 8/1: Mar 14 14:27:21.524: %UBR10000-5-UPDOWN: Interface Cable8/1/0 U3, changed state to administratively down
SLOT 8/1: Mar 14 14:27:21.784: %UBR10000-5-UPDOWN: Interface Cable8/1/1 U0, changed state to administratively down
SLOT 8/1: Mar 14 14:27:21.784: %UBR10000-5-UPDOWN: Interface Cable8/1/1 U1, changed state to administratively down
SLOT 8/1: Mar 14 14:27:21.784: %UBR10000-5-UPDOWN: Interface Cable8/1/1 U2, changed state to administratively down
SLOT 8/1: Mar 14 14:27:21.784: %UBR10000-5-UPDOWN: Interface Cable8/1/1 U3, changed state to administratively down
SLOT 8/1: Mar 14 14:27:22.736: %UBR10000-5-UPDOWN: Interface Cable8/1/2 U0, changed state to administratively down
*Mar 14 14:27:24.824: %IPCOIR-2-CARD_UP_DOWN: Card in slot 8/1 is up.  Notifying ubr10k-clc-mc2020v driver.
SLOT 8/1: Mar 14 14:27:24.756: Nickel10g - Waxbill SPI port is in sync
*Mar 14 14:27:25.924: %UBR10000-5-UPDOWN: Interface Cable8/1/2 U0, changed state to administratively down
*Mar 14 14:27:25.924: %UBR10000-5-UPDOWN: Interface Cable8/1/2 U1, changed state to administratively down
*Mar 14 14:27:25.924: %UBR10000-5-UPDOWN: Interface Cable8/1/2 U2, changed state to administratively down
*Mar 14 14:27:25.924: %UBR10000-5-UPDOWN: Interface Cable8/1/2 U3, changed state to administratively down
*Mar 14 14:27:25.924: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable8/1/2, changed state to up
*Mar 14 14:27:25.928: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/1/2 changed state to up
*Mar 14 14:27:26.420: %UBR10000-5-UPDOWN: Interface Cable8/1/3 U0, changed state to administratively down
*Mar 14 14:27:26.420: %UBR10000-5-UPDOWN: Interface Cable8/1/3 U1, changed state to administratively down
*Mar 14 14:27:26.420: %UBR10000-5-UPDOWN: Interface Cable8/1/3 U2, changed state to administratively down
*Mar 14 14:27:26.420: %UBR10000-5-UPDOWN: Interface Cable8/1/3 U3, changed state to administratively down
SLOT 8/0: *Mar  1 00:00:54.011: %IPCGRP-6-UCODEVER: Reported microcode version, 1338851047.
SLOT 8/0: Mar 14 14:27:23.516: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U0, changed state to administratively down
SLOT 8/0: Mar 14 14:27:23.516: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U1, changed state to administratively down
SLOT 8/0: Mar 14 14:27:23.520: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U2, changed state to administratively down
SLOT 8/0: Mar 14 14:27:23.520: %UBR10000-5-UPDOWN: Interface Cable8/0/0 U3, changed state to administratively down
SLOT 8/0: Mar 14 14:27:23.784: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U0, changed state to administratively down
SLOT 8/0: Mar 14 14:27:23.784: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U1, changed state to administratively down
SLOT 8/0: Mar 14 14:27:23.784: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U2, changed state to administratively down
SLOT 8/0: Mar 14 14:27:23.784: %UBR10000-5-UPDOWN: Interface Cable8/0/1 U3, changed state to administratively down
SLOT 8/0: Mar 14 14:27:24.736: %UBR10000-5-UPDOWN: Interface Cable8/0/2 U0, changed state to administratively down
*Mar 14 14:27:26.836: %LINK-3-UPDOWN: Interface Cable8/1/4, changed state to up
*Mar 14 14:27:26.864: %IPCOIR-2-CARD_UP_DOWN: Card in slot 8/0 is up.  Notifying ubr10k-clc-mc2020v driver.
SLOT 8/0: Mar 14 14:27:26.080: Nickel10g - Waxbill SPI port is in sync
*Mar 14 14:27:27.924: %UBR10000-5-UPDOWN: Interface Cable8/0/2 U0, changed state to administratively down
*Mar 14 14:27:27.924: %UBR10000-5-UPDOWN: Interface Cable8/0/2 U1, changed state to administratively down
*Mar 14 14:27:27.924: %UBR10000-5-UPDOWN: Interface Cable8/0/2 U2, changed state to administratively down
*Mar 14 14:27:27.924: %UBR10000-5-UPDOWN: Interface Cable8/0/2 U3, changed state to administratively down
*Mar 14 14:27:27.924: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable8/0/2, changed state to up
*Mar 14 14:27:27.924: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/0/2 changed state to up
*Mar 14 14:27:28.432: %UBR10000-5-UPDOWN: Interface Cable8/0/3 U0, changed state to administratively down
*Mar 14 14:27:28.432: %UBR10000-5-UPDOWN: Interface Cable8/0/3 U1, changed state to administratively down
*Mar 14 14:27:28.432: %UBR10000-5-UPDOWN: Interface Cable8/0/3 U2, changed state to administratively down
*Mar 14 14:27:28.432: %UBR10000-5-UPDOWN: Interface Cable8/0/3 U3, changed state to administratively down
*Mar 14 14:27:28.880: %LINK-3-UPDOWN: Interface Cable8/0/4, changed state to up
*Mar 14 14:27:28.884: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable8/0/4, changed state to up
*Mar 14 14:27:28.884: %SNMP-5-LINK_UP: LinkUp:Interface Cable8/0/4 changed state to up
*Mar 14 14:27:29.088: %UBR10000-5-UPDOWN: Interface Cable8/0/4 U0, changed state to administratively down
*Mar 14 14:27:29.088: %UBR10000-5-UPDOWN: Interface Cable8/0/4 U1, changed state to administratively down
*Mar 14 14:27:29.088: %UBR10000-5-UPDOWN: Interface Cable8/0/4 U2, changed state to administratively down
*Mar 14 14:27:29.088: %UBR10000-5-UPDOWN: Interface Cable8/0/4 U3, changed state to administratively down
Acaco_3.0>
Acaco_3.0>en
Password:
Press RETURN to get started.
Hasta aqui me quede...
Hola @frajvep ,
Prueba con esto(este es el procedimiento en los router):
En el modo privilegiado ingresa el comando erase startup-config
#erase startup-config
Luego el equipo deberia pedirte que confirmes
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
Confirmas solo apretando enter
El equipo te confirmará que la información de la nvram se borró
Erase of nvram: complete
Entonces volverás al modo privilegiado y debes ingresar el comando reload para reiniciar el equipo y que empiece de cero.
#reload
Te pedirá confirmar nuevamente antes de reiniciar el equipo
Proceed with reload? [confirm]
Cuando reinicie, te hará la pregunta que te comenté al inicio de la discusión
La respuesta siempre es no
Esto te dejará en el modo usuario para iniciar con las configuraciones
Saludos
Recuerda marcar como solución las respuestas correctas, ya que eso ayuda a otros usuarios con dudas parecidas.
5 Replies 5
luis_cordova
Hola @frajvep ,
Te sugiero desenchufar el equipo y volver a encenderlo.
Una vez que cargue y llegue a este punto:
Pon como respuesta: no
Con ello, el router cargará el archivo de configuración y te dejará en el modo de usuario:
Tonala>
Espero que eso te sea útil.
Recuerda marcar como solución las respuestas correctas.
Saludos
Tonala es mi cmt que esta en otro CRC, el que estoy configurano es nuevo y en otro CRC.
Estoy empenzando desde cero, lo que dices no aplica por que en ningun momento eh puesto Tonala:
Hola @frajvep ,
Sorry, pensé que la configuración que mostrabas era la que habías hecho en el nuevo equipo, y cómo vi el comando hostname Tonala supuse que el equipo quedaría con ese nombre.
En si, lo que quise decir es que al momento de encontrar la pregunta:
debes ingresar no, con lo que el equipo te dejara en modo usuario, listo para seguir con el configurado normal del equipo.
Saludos
Gracias.
Amigo pregunta, como puedo resetear el uBR10000, para dejarlo de fabrica de nuevo.
Saludos
Hola @frajvep ,
#reload
Saludos
