ARP statistics Drop due to Input Queue Full
viplove
Frequent Visitor
Frequent Visitor
I am observing ARP input Queue full and dropping packets.
At the same time Observing CPU high due to PID 9 which belongs to ARP Input. Kindly suggest solution, customer is dropping connections to their servers.
007152: Mar 15 12:03:32.816: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Utilization(Total/Intr): 91%/26%, Top 3 processes(Pid/Util): 9/46%, 211/7%, 267/2%
9 107058250 495013478 216 0.47% 0.43% 0.44% 0 ARP Input
tnp_ctt_ctp34_01_sw_01#show ip traffic | in input
Drop due to input queue full: 1860186
Kindly suggest a solution
Remi Astruc
Level 8
Level 8
Can you please issue the following commands and give the outputs:
show ver
show ip traffic
show int | i Input queue|line protocol is up
Remi Astruc
Show ver :
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 16:29 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
tnp_ctt_ctp34_01_sw_01 uptime is 45 weeks, 3 days, 2 hours, 23 minutes
System restarted at 11:45:29 SAST Tue May 1 2018
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision H0) with 131072K bytes of memory.
Processor board ID FOC1446V3Z9
Last reset from power-on
4 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 08:17:35:41:E6:00
Motherboard assembly number : 73-10219-09
Power supply part number : 341-0098-02
Motherboard serial number : FOC14464P62
Power supply serial number : AZS143912PF
Model revision number : H0
Motherboard revision number : A0
Model number : WS-C3750G-24TS-S1U
System serial number : FOC1446V3Z9
Top Assembly Part Number : 800-26859-03
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : COMB600BRA
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS-1U 12.2(55)SE3 C3750-IPSERVICESK9-M
Configuration register is 0xF
Show Ip Traffic:
IP statistics:
Rcvd: 278594504 total, 208859258 local destination
0 format errors, 0 checksum errors, 0 bad hop count
0 unknown protocol, 69735246 not a gateway
0 security failures, 0 bad options, 1123742 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 1123742 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 couldn't fragment
Bcast: 197910334 received, 0 sent
Mcast: 0 received, 0 sent
Sent: 12600531 generated, 0 forwarded
Drop: 364355 encapsulation failed, 0 unresolved, 0 no adjacency
0 no route, 0 unicast RPF, 0 forced drop
0 options denied, 0 source IP address zero
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 1 redirects, 27980 unreachable
1235104 echo, 117634 echo reply, 33 mask requests, 0 mask replies, 0 quench
0 parameter, 11 timestamp, 0 info request, 11 other
0 irdp solicitations, 0 irdp advertisements
Sent: 0 redirects, 5895 unreachable, 117735 echo, 1235104 echo reply
0 mask requests, 0 mask replies, 0 quench, 11 timestamp
0 info reply, 0 time exceeded, 0 parameter problem
TCP statistics:
Rcvd: 797085 total, 0 checksum errors, 446 no port
Sent: 1045663 total
UDP statistics:
Rcvd: 206681337 total, 10 checksum errors, 185575835 no port
Sent: 10196153 total, 0 forwarded broadcasts
BGP statistics:
Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
0 keepalives, 0 route-refresh, 0 unrecognized
Sent: 0 total, 0 opens, 0 notifications, 0 updates
EIGRP-IPv4 statistics:
Rcvd: 0 total
Sent: 0 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
OSPF statistics:
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
ARP statistics:
Rcvd: 635583950 requests, 3023824 replies, 335149 reverse, 0 other
Sent: 1965 requests, 22512202 replies (0 proxy), 0 reverse
Drop due to input queue full: 1863016
#show int | i Input queue|line protocol is up
Vlan1 is up, line protocol is up
Vlan2 is up, line protocol is up
Vlan300 is up, line protocol is up
GigabitEthernet1/0/1 is up, line protocol is up (connected)
GigabitEthernet1/0/2 is up, line protocol is up (connected)
GigabitEthernet1/0/3 is up, line protocol is up (connected)
GigabitEthernet1/0/4 is up, line protocol is up (connected)
GigabitEthernet1/0/5 is up, line protocol is up (connected)
GigabitEthernet1/0/6 is up, line protocol is up (connected)
GigabitEthernet1/0/7 is up, line protocol is up (connected)
GigabitEthernet1/0/25 is up, line protocol is up (connected)
Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 200
GigabitEthernet1/0/26 is up, line protocol is up (connected)
Loopback0 is up, line protocol is up
The problem is well related to ARP traffic.
During the problem, please run few times the 2 commands below, to get a sampled base:
sh clock
sh ip traffic | b ARP
By the way, your platform is older than Gandalf.
Remi Astruc
