Backplane and Throughput Difference
sumesh_un
What is the difference between the terms'backplane' of a switch (often in Gbps) and the 'throughput' of a switch (in Mpps) ?
Are they interdependent?
MATTHEW BECK
Level 3
Level 3
I just asked a similar question and received an excellent response. Try this link:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc22269/3
And if that doesn't work, search for posts with my name in them and you will find what you're looking for.
