Backplane, NVI, Null0
NInja Black
 I recently installed a EHWIC card on the Cisco 3925 router. After that I saw in my network monitoring tool that the interfaces Backplane, NVI, Null0 have started showing bandwidth utilisation. I understand the bandwidth util in the 'Backplane-GigabitEthernet0/3-Ba0/3' is because of the EHWIC card but whYis there traffic showing now in NVI and Null0 interfaces?
Thank you for the config.
You are using the NVI style of NAT - you have your interfaces configured with ip nat enable instead of inside/outside, and you are using the ip nat source command to activate the address translation. This style of NAT configuration may result in packets being internally forwarded over the virtual NVI0 interface to allow IOS to do its NATting work. Therefore, I would say that seeing packets being forwarded by NVI0 interface is normal and is the result of the way you have your NAT configured.
Regarding the Null0 interface, it is generally difficult to say why packets are being forwarded over this interface - and discarded as a result. You may want to see the show ip cef and show ip cef null0 command outputs to see what routing entries point toward this interface and see if they match any traffic that could possibly be generated by stations attached to your router.
As I indicated earlier, finding out what traffic is forwarded over NVI0 and Null0 can be a nice detective work, but as long as you do not perceive any connectivity or throughput issues, I recommend viewing it just as a curiosity.
Best regards,
Peter
Peter Paluch
To be honest, I haven't done this kind of monitoring on routers because the NVI and Null0 interfaces are virtual interfaces whose load I never considered to be relevant. Nonetheless, we could perhaps try to at least guess what is going on but for that, we would need to see your running-config. Is it possible for you to post it after removing sensitive information?
Thanks!
Best regards,
Peter
Thanks for your response peter.
Any insight would be great.
 Below is the output.
Cisco3925# sh run
Building configuration...
Current configuration : 9353 bytes
######### OUTPUT OMITTED #########
version 15.3
service password-encryption
hostname Cisco3925
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
enable XXX XXXX XXXXXX
no aaa new-model
clock timezone EST -5 0
ip domain name XXXXXXXX
ip name-server 75.75.75.75
ip name-server 75.75.76.76
ip name-server 4.2.2.1
ip name-server 4.2.2.2
ip cef
login block-for 60 attempts 5 within 30
login on-failure log
login on-success log
ipv6 unicast-routing
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
ipv6 cef
crypto pki trustpoint TP-self-signed-2051591686
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2051591686
 revocation-check none
 rsakeypair TP-self-signed-2051591686
crypto pki certificate chain TP-self-signed-2051591686
 certificate self-signed 01
  C40DCAFB 59866F25 06A6AC32 13F85A
      quit
license udi pid C3900-SPE100/K9 sn FOC17364MQB
archive
 log config
  logging enable
  notify syslog contenttype plaintext
redundancy
class-map match-any CAsip
 match protocol sip
 match protocol rtcp
 match protocol rtp
 match protocol rtsp
policy-map CAqos
 class CAsip
  priority percent 65
  set dscp ef
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description ENS_Link
 ip address 10.XX.XX.XX 255.255.255.0
 ip access-group 120 in
 ip virtual-reassembly in
 duplex full
 speed 100
 ipv6 enable
interface GigabitEthernet0/1
 description ISP1
 ip address 50.XX.XX.XX 255.255.255.252
 ip access-group 199 in
 no ip redirects
 ip nat enable
 duplex full
 speed 100
 ipv6 enable
 hold-queue 1500 in
interface GigabitEthernet0/2
 description ISP2
 no ip redirects
 duplex auto
 speed auto
 ipv6 enable
interface GigabitEthernet0/0/0
 switchport access vlan 10
 no ip address
interface GigabitEthernet0/0/1
 no ip address
interface GigabitEthernet0/0/2
 no ip address
interface GigabitEthernet0/0/3
 no ip address
interface Vlan1
 no ip address
interface Vlan10
 description XXX
 ip address 10.XX.XX.XX 255.255.255.248
 no ip redirects
 ip nat enable
 service-policy output CAqos
router eigrp 101
 network 10.XX.XX.XX 0.0.0.255
 redistribute connected
 redistribute static
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source list 10 interface GigabitEthernet0/1 overload
i######### OUTPUT OMITTED #########
ip route 0.0.0.0 0.0.0.0 50.XX.XX.XX
######### OUTPUT OMITTED #########!
logging host 10.XX.XX.XX
snmp-server community XX RW
snmp-server chassis-id Cisco3925-XX
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server host 10.XX.XX.XX version 2c XX
access-list 10 permit 10.XX.XX.XX 0.0.0.7
access-list 120 permit ip any any
access-list 199 deny   tcp any any eq telnet
access-list 199 permit ip any any
access-list 199 permit icmp any any
control-plane
banner exec ^CCC
######### OUTPUT OMITTED #########^C
line con 0
 exec-timeout 5 30
 privilege level 15
 password 7 XXXX
 login local
line aux 0
 privilege level 15
 password 7 XXXX
 login local
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 timeout login response 300
 privilege level 15
 password 7 XXXX
 login local
 transport input telnet ssh
line vty 5 15
 privilege level 15
 password 7 XXXX
 login local
scheduler allocate 20000 1000
ntp master 3
ntp peer 10.XX.XX.XX
end
Cisco3925#
Cisco3925#
Cisco3925#
Cisco3925#
Best regards,
Peter
Thanks Peter.
 Sorry I couldn't get back to you earlier.
I do not see any output for sh ip cef null0.
But I am not going to worry about it as its not causing any issues. Just wanted to get some info on it and your reply helped.
Thanks!!!
