05-22-2010 04:33 AM - edited 03-06-2019 11:13 AM
I have been trying to trunk to 2960 switches and can't seem to get a proper connection. I am using packet tacer. The 1st switch already has a trunk port going to a router and the router has port is trunked and has sub ints for each of vlans 2 and 3 and each sub trunk has respective native encap vlan configured. My management vlan is vlan 3. And I don't have an int vlan1 only int vlan 3. The router and the 1st siwtch work fine. But now I am trying to get another trunk port with second switch. I configured both ints for trunking using native vlan 1. Now the links are in up state but both ends are not leds green, one is orange. And I have only int vlan 3 as with other switch and ip in same subnet as managment ip but cannot ping. Strange thing vtp info can pass but no connection to other switch vlans and router etc, only local connectivity. Plz help, below is the configs of the rotuer and two switches. It is switch 1 that is giving me beans to connect to the rest.
Router0
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname RouterA
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
username admin secret 5 $1$mERr$vPOtdREpWgzFVVY37SB2h/
ip name-server 0.0.0.0
interface Loopback0
description management
interface Loopback1
ip address 192.168.2.1 255.255.255.224
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.5.0.1 255.255.255.0
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 192.168.4.1 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0
ip address 172.16.1.1 255.255.255.252
interface Serial0/1
no ip address
interface FastEthernet1/0
no ip address
duplex auto
speed auto
interface FastEthernet1/1
no ip address
duplex auto
speed auto
router rip
version 2
network 172.16.0.0
network 192.168.1.0
network 192.168.2.0
no auto-summary
ip classless
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit host 192.168.4.2
line con 0
line vty 0 4
access-class 1 in
password 7 08316C5D1A2E5505165A
login
end
Switch 0 (connected to Router 0)
version 12.2
hostname SwitchA
no logging console
username admin password 7 08651D0A043C3705561E0B54322E2B3C2B063137324232064274
spanning-tree portfast default
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 3
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 2
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
switchport mode trunk
interface FastEthernet0/19
switchport mode access
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
no ip address
interface Vlan3
ip address 192.168.4.10 255.255.255.0
ip default-gateway 192.168.4.1
access-list 1 permit host 192.168.4.1
line con 0
line vty 0 4
access-class 1 in
login
line vty 5 15
login
end
Switch 1 (connected to Switch0) (This is the second switch which I cannot get connected to rest of network properly)
version 12.2
hostname Switch
interface Vlan1
no ip address
interface Vlan3
ip address 192.168.4.20 255.255.255.0
line con 0
line vty 0 4
login
line vty 5 15
login
end
05-22-2010 04:54 AM
Use show interface fastethernet 0/18 trunk , show interface fastethernet 0/23 trunk, show interface fastethernet 0/18 trunk and check whether the trunking is on.
if possible post the output here.
regds
05-22-2010 05:29 AM
Yes is up via sh switchport
Switch0
Switch0#sh int f0/24 switchport (connected to Router, 1st trunk on Switch0) (works well with communication and inter vlan routing)
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
Switch0
Switch0#sh int f0/18 switchport (connected to Switch 1) (second trunk on Switch0)
Switchport: Enabled
Voice VLAN: none
Protected: false
Switch 1 (can't ping Switch0 nor Router) (connected to second trunk on Switch 0)
Switch1#sh int f0/18 switchport
Switchport: Enabled
Voice VLAN: none
Protected: false
VTP info is passing so I know the 2nd trunk between Switch0 and Switch1 is up. But for some reason, I don't know why they cannot ping each other. On both switches they both have SVI's in vlan 3. SVI vlan 1 is up also on bith switches but no ip's assigned. I am using SVI's only on vlan 3. My managment vlan is vlan 3. Objective is to have all my devices be managed by subnet assigned to vlan 3 SVI's. Router int f0/0.3 (vlan3) is 192.168.4.1, Switch 0 int vlan 3 is 192.168.4.10 and Switch 1 int vlan 3 is 192.168.4.20. Only Switch 1 cannot ping the rest of devices. Its port led is green but on the other end on Switch 0 its orange. Appreciate input, I am confused , but maybe somehing i am missing
05-23-2010 09:26 PM
My problem was stp putting the port in blocking stat to avoid loop. That inturn was breaking the trunk. I created etherchannel between the two switches and this solved things.
