Balancing load over DSL cards
ffranco123
I need help.I'm trying to configure one FastEthernet with 5 Vlans,and need to do traffic balancing over two Dsl cards.How can I do it?
I have attached the config of my router.
Thanks in advance.
archari
Cant see the config .. but at a very high level. Two default static routes pointing out to each of the remote DSL gateway IP addresses should do the trick.
CEF will take care of the per destination load balancing once the routing is configured correctly.
ip route 0.0.0.0 0.0.0.0
I assume here that your destination is the internet hence the default route. If not replace 0.0.0.0 by whatever destination you want to balance out to.
