Bandwidth Management through Cisco Router
Mero Cisco
I have got an cisco router with 3 interface. Interface FA 0/0 is an outside interface and interface fa0/1 and fa0/2 are inside interface.
Int Fa0/0
Desc Connected to Outside, the inside internet traffic passes through this router
ip address 192.168.200.1 255.255.255.0
Int Fa0/1
Desc Connected to Remote
Ip Address 10.10.0.1 255.255.0.0
Int Fa0/2
Desc Connected to HO
Ip Address 192.168.100.1 255.255.255.0
Now I want to apply bandwidth restriction as follows:
1. Full Bandwidth for Private Address from all sources.
2. Full Bandwidth for 173.194.38.150, 209.191.122.42 from all sources
3. 1 Mbps limitation for 202.51.65.57 through 10.10.10.0/24, 10.10.20.0/24 and 10.10.30.0/24
4. 2 Mbps limitation for 202.51.69.57 through 10.10.101.0/24, 10.10.201.0/24 and 10.10.205.0/24
5. Full Bandwidth from 192.168.100.0/24 to any
6. 0 Mbps internet for rest.
Is this possible in cisco router, please guide me.
Thanks in advance
- Mero
Mero Cisco
Pls help
hi,
    just go to each int and try out the bandwith command. it might help.. what is the model of router .
example:
 bandwidth 128 (this is in kilobits)
http://certcollection.org/forum/topic/55536-limit-bandwidth-on-a-cisco-catalyst-switch-port/
Mero Cisco
Dear Anirudh,
Cisco 1841, bandwidth mgmt to each interface won't work because it have to be unlimited for private ip and also unlimited for some public ip
Mero
