Bandwidth policing by IP
Epiccloud
We are trying to setup QoS Bandwidth policing by subnet but the policies we've defined aren't getting any hits. Only the default policy is applying.
All of our /24 subnets terminate on the 3850 stack, we are trying to police bandwidth inbound/outbound via interfaces tied to VLAN 2 and VLAN 3 to our edge routers.
class-map match-any GOLD
 match access-group name GOLD_staff
class-map match-any BRONZE
 match access-group name BRONZE_staff
class-map match-any PLATINUM
 match access-group name PLATINUM_staff
class-map match-any SILVER
 match access-group name SILVER_staff
policy-map PoliceBandwidth
 class BRONZE
  police cir 10240000 bc 312500 conform-action transmit  exceed-action drop
 class SILVER
  police cir 25600000 bc 312500 conform-action transmit  exceed-action drop
 class GOLD
  police cir 51200000 bc 312500 conform-action transmit  exceed-action drop
 class PLATINUM
  police cir 102400000 bc 312500 conform-action transmit  exceed-action drop
 class class-default
interface GigabitEthernet1/0/1
 switchport access vlan 2
 switchport mode access
 service-policy input PoliceBandwidth
 service-policy output PoliceBandwidth
interface GigabitEthernet1/0/2
 switchport access vlan 3
ip access-list extended BRONZE_staff
 permit ip 192.168.100.0 0.0.0.255 any
ip access-list extended SILVER_staff
 permit ip 192.168.101.0 0.0.0.255 any
ip access-list extended GOLD_staff
 permit ip 192.168.102.0 0.0.0.255 any
ip access-list extended PLATINUM_staff
 permit ip 192.168.103.0 0.0.0.255 any
Philip D'Ath
If you want to police in both directions, your access lists are going to have to match in both directions.  e,g.
 permit ip any 192.168.100.0 0.0.0.255
Try putting the service policy on the actual VLAN interfaces if you don't make progress.
Philip D'Ath
Adding the reciprocal path to the access-list seems to be working, thanks!
When I try to add;
to the vlan interface the commands don't stick and don't show up in the configuration?
I can only assume this switch doesn't support service policies on VLAN interfaces
