Bandwidth Problems of Subnets in the same Vlan
mehmethyeni
Hi Community,
We have faced a strange problem in our customer while implementing non-cisco switches in their network. Firstly, we suspected from the switches but when we remove the newly installed switches from the network the problems still go on in cisco devices. The bandwidth when we transfer some files between vlan 3 subnets couldn't reach 10Mbps. But from any vlan 3 subnets to Vlan 1 or vlan 200 subnets, it easily reach 100Mbps.
Let me exceed the details of problems. Customer has 3 vlans and their subnets like this:
Vlan 3:
X.Y.124.0/24
X.Y.123.0/24
X.Y.121.0/24
X.Y.120.0/24
X.Y.96.64/26
X.Y.126.0/24
X.Y.96.0/26
Vlan 1:
X.Y.96.192/26
X.Y.126.0/24
Vlan 200:
X.Y.127.0/24
As you can see in the basic topology, we make our tests via winscp by transferring files. Here are some test results that we made.
SERVERTEST-PCBandwidth Rate
X.Y.96.3X.Y.96.878 Mbps
X.Y.96.3X.Y.96.10100 Mbps
X.Y.96.3X.Y.120.20010 Mbps
X.Y.96.3X.Y.121.20010 Mbps
X.Y.96.3X.Y.96.20095 Mbps
X.Y.96.3X.Y.126.20095 Mbps
X.Y.96.3X.Y.127.200100 Mbps
X.Y.127.201X.Y.126.200100 Mbps
Shortly,
Vlan 1 to vlan 200, 3 subnets --> all OK, 100 Mbps
Vlan 200 to Vlan 1,3 subnets --> all OK, 100 Mbps
Vlan 3 to Vlan 1,200 subnets --> all OK, 100 Mbps
Vlan 3 between its subnets --> problem, max 10 Mbps
Vlan 3 in the same subnet host --> all OK, 100 Mbps
What can be done in this situation?
5 Replies 5
Ganesh Hariharan
       Hello ,
What switch model are you using and could it be possie for you to share th interface stats what is hapein when traferring the data from PC over vlan 3 to others.
Ganeshh Iyer
Actually customer divided subnets to 2 vlans (vlan1 and 3) for entering the traffic to the IPS a couple years ago. When I change any subnet's vlan membership from 3 to 1, the problem seems resolved. Another interesting thing  is that when I disable IPS, problem still goes on unless I change subnet's vlan. Finally, I have to manage IPS in another way.
Thank you,
Thank you,
It would be helpful if you can represent in diagramatic presentation what exactly is issue is ....
Hari Haran S M
Hi Mehmet,
Where is the intervlan routing? I see that you have different subnets in vlan 3. How is the routing between these subnets?
Hari
HI Mehmet,
what about the duplex settings? How did they negotiate them? Try to hardcode the speed and the values and to disable DTP.. After this check the CRC on the interfaces..If this issue persist it probably would be a good idea to re-configure the broadcast domains and/or to tune them
Hope this helps
Alessio
