Bandwidth restriction for ftp traffic only on a an uplink port of a 3750X LAN switch?
msamsamieh
Hi All,
I have a requirement to restrict the available  bandwidth for ftp (Data and Control) ONLY on an 1G uplink port of a 3750X switch
(from any source to any destination) while making the remaining bandwidth available for all other traffic.
I am trying to explore the possible options to do so but so far I have reached only one possible scenario which restricts the bandwidth for
all traffic and not for ftp specifically:
Switch(config)# interface GigabitEthernet 1/0/25
Switch(config-if)# srr-queue bandwidth limit 30
But the above would interface BW on the port for all traffic to 30% of avaliable link BW.
Appreciate any suggestions that would help me out asap!
Moe
The policing is the easy part of the config ... More difficult is to match on FTP with the limited capabilities of the Catalyst.
Is it for your own FTP-server or for servers on the internet?
If it is for Servers on the internet: No way to do it on your Switch. Do it on the internet-firewall or the internet-router instead.
If it's for your own server:
  1. Set the server to a specific port-range for passive FTP
  2. Configure an ACL on the switch for classifying the data- and control-traffic
  3. configure a policer that drops all traffic above your limit.
or better:
Reconfigure the server(s) for bandwidth limits.
All in all, IMO the switch is the wrong device for the right job.
zoltan.gyonyoru
Hi Moe,
INGRESS:
for example limit traffic to 50 Mbps:
policy-map PM_FTP_LIMIT
 class CM_FTP
  police 52428800 80000 exceed-action drop
interface Gig X/Y/Z
 service-policy input PM_FTP_LIMIT
(Of course you need to create an ACL matching FTP and also a Class-map matching that ACL)
EGRESS:
interface Gig X/Y/Z
 srr-queue bandwidth shape 0 0 0 20
If your FTP traffic is in queue 4 it will limit it to 50 Mbps on a 1 Gig interface: (1/20)*1000=50
Make sure nothing else mapped to queue 4, or use different queue-set (2) if possible
Zoltan
