SFP line card for VS-S720-10GE-3C in VSS mode
chrismillion
Hi, I need a GB SFP module that support VSS with VS-S720-10GE-3C.
I read the cards need to support DFC3...
Will the DFC4 cards work, such as WS-X6824-SFP-2T ?
I assume the non-DFC3 cards will not, such as  WS-X6724-SFP?
Can a DFC3 daughter card be added to  WS-X6724-SFP?
Thanks!
Leo Laohoo
VS-S720-10GE-3C
Means DFC3C.
Check the module.  DFC3C is NOT compatible with the 3A or 3B.
OK thanks.
Is VS-S720-10GE-3C compatible with 4C cards?
Can a DFC3C be added to WS-X6724-SFP?
No & no.
Are you sure?  I think these 2 links say you can add WS-F6700-DFC3C to a WS-X6724-SFP.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_15893.html#wp85495
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Module_Installation/Mod_Install_Guide/6500-emig/0adtrcrd.html#wp1007726
