Bandwidth value on Cisco 3850 Gigabit interface
sreeraj.murali
Level 3
Level 3
Hi Experts,
I have a Gigabit Interface on Cisco 3850 switch connected to the MPLS Router Gigabit interface which is of Cisco 1900 series. I need help is setting the bandwidth value on the switch interface.
I am seeing the below result, when trying to configure manually, instead of leaving as AUTO negotiated.
IN-BG_NEW-00-ETHER-0(config-if)#bandwidth ?
  <1-10000000>  Bandwidth in kilobits
  inherit       Specify how bandwidth is inherited
Please suggest the recommended value for the bandwidth settings for the Gigabit interface, which is getting connected to Gigabit interface of Cisco Router.
Sreeraj
Julio E. Moisa
I usually configure bandwidth command on routers but should same on switches
interface g1/0/1
no switchport   <--- To make the port L3 and be able to use IP addresses
bandwidth 1000000
1,000,000 = 1 Gigabit.
But you could not need this change, check first the current bandwidth through the following command:
show interface g1/0/1
and you will se the current bandwidth.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
interface g1/0/1
bandwidth 1000000
Hope it is useful
Thank you !!!
You are welcome, have a great day!
