Basic CCENT question.
Good Afternoon,
Currently I am studying CCENT while working as an assistant within a police network team. I have noticed, upon reading my CCENT book that it states that a Switch doesnt create multiple broadcast domains (table 6-3, page 158 official cert guide). Surely this is incorrect as VLANs on a switch would create separate broadcast domains. Is it a matter of wording as in, the switch would not create the broadcast domain automatically without configuration?
Am I misunderstanding something? I was just wondering as I would hate to get to the exam and find that I was answering simple questions wrong.
Many Thanks.
It is the general concept of switch. There are switches that do not support VLAN. Vlan is an extra feature switch can support.
If we just look at the concept.
Hub : only one collision domain, one broadcast domain
Switch: several colission domains, one broadcast domain.
Router: several broadcast domains.
Hope it helps,
Masoud
8 Replies 8
Hope it helps,
Masoud
Thanks for your helpful response, ill bear it in mind.
You are most welcome.
Masoud
Comments: i am going to take the course, I purchased the book , and being told that i needed more notes and that the study guide is not enough? Do I need to learn the 36 chapters or can I just focus on the exam topics?
haadk170190
From CCNA and CCNP my advice would be you need to have good knowledge in a variety of areas (not just zone in on certain areas)
For you subnetting and network fundamentals in general are a must.
Martin
One more thing on the switches. For the CCNA level certification, a switch is a layer 2 device not a layer 3 device. While there are switches that can do layer 3 routing, for the CCNA level certification it is strictly tested as a layer 2 device.
Mike
The answer is determined by what the question is asking.
Martin
