Basic Help with 1720 and NAT
mattwilson247
I have a Cisco 1720 router and I am able to log in to it via telnet and enable the advanced features. I want to match up one of our external IP addresses to an internal IP address. I guess that I use NAT to do this but I don't know any of the commands. How would I do this? There are already a few IPs doing this (our mailserver and firewall). I didn't configure the router but I have access to it. Thanks.
-Matt
sachinraja
Level 9
Level 9
Hi Matt,
You need to take a free IP on the inside as well as the outside interface. after this, u need to do a static mapping on the router, as given below:
config)#ip nat inside source static 10.10.10.1 202.1.1.1
where 10.10.10.1 is the inside private IP and 202.1.1.1 is the ISP global IP.
I think the nat inside/outside commands will already be there on ur interfaces, since u have told that there exists a nat already for mail server.. otherwise, just add these commands:
interface ethernet0
description CONNECTED TO LAN
ip nat inside
interface serial 0/0
description CONNECTED TO INTERNET
ip nat outside.
hope this helps.. all the best.
That helps a bit. So at the command line all I type in is:
With the IPs as my IPs of course. The ) looks out of place. Was that a mistake? Then do I have to save the configuration? What do I do if I want to delete the interface at a later time?
Thanks.
-Matt
