Basic HSRP Question
gregwoodson
I've configured HSRP on many occassions, but cannot seem to find the answer to this.  Can you configure HSRP on 4 routers instead of just 2?  Obviously being able to set the priority suggests that is possible- but I just wanted to make sure.  Are there any problems with this?
Greg
Jon Marshall
Greg
Greg
Yes there is no problem with configuring HSRP across 4 routers, as long as they all L2 adjacency to each other it will work.
Jon
Jon Marshall
Greg
Greg
Jon
