Basic import of SSL cert on 9200 for web UI SSL
I am trying to complete a basic import of a certificate to our 9200 switches, so that it covers the HTTPS access via the web GUI.
I am however struggling a bit, and Cisco first line support don't quite have the knowledge to clearly guide me.
I have used OpenSSL to generate a CSR and private key, with a common name and SAN for the switch.
I have then used the CSR to generate a base64 certificate from our AD CA.
I am trying to run
crypto pki import CERTNAME pem terminal password KEYPASSWORD
I am asked to enter the base64 data for the CA root cert (which I have done), the encrypted key (which I have obtained from the openssl generated key file, and the cert itself, which I have from the AD CA.
When I enter all this though, the command fails with:
Unable to decode key.
% PEM files import failed.
Does anyone have any thoughts on where I may have gone wrong?
James
I have a resolution to this problem. Cisco support advised my issue was that the cert was missing DEK header information.
So, my process is;
1. Generate key and CSR using below command:
openssl req -newkey rsa:2048 -subj "[certificate_details]" -sha256 -keyout [key_name].key -out [csr_name].csr -config [ConfigFilePath]\openssl-san.cnf
2. Convert the key or add DEK header info using the below command:
openssl rsa -in keyin.key -out keyout.key -des3
3. Generate cert from CSR
4. Import cert to switch using below command:
crypto pki import TRUSTPOINT_NAME pem terminal password KEY_PASSWORD
5. Enter the root CA cert, key and cert text when prompted
6. Set the trustpoint as the one used for https using below command:
ip http secure-trustpoint TRUSTPOINT_NAME
Hope this helps others.
James
Can anyone guide me on this?
Cisco support are suggesting a much more convoluted process to convert the certs into PFXs, upload via FTP, and then install to the switch.
The switch provides commands that look to suggest I should be able to import directly from a PEM and KEY, but it doesn't seem to work and they aren't being too helpful in helping me figure out why.
Cheers
James
MichaelHusk
Hey James,
Were you able to resolve this issue? I am having the same problem.
Hi MIchael,
I have been working with Cisco support for some time on this issue, but they keep telling me to go through some convoluted process to convert the file to a PFX, upload it to the switch via FTP or SCP etc. then import it from switch storage.
This is a headache for me, nightmare for anyone with a larger fleet of switches.
It has been escalated, and I am trying to understand why this process is failing, and whether or not it is a supported/expected procedure to follow.
Will update as soon as I have a concrete answer.
Many thanks
James
So, my process is;
James
