Basic query regarding ACL
mukundh86
I have  a very basic question regarding ACL operation. Say I have an access-list as follows
access-list 101 deny ip any host 4.2.2.2
access-list 101 permit tcp any host 4.2.2.2 eq 80
If my understanding is correct, tany http traffic to 4.2.2.2 will be denied right?
For the same access-list will http traffic to 4.2.2.2 be denied if replace the first statement with deny icmp any host 4.2.2.2?
Mukundh
cadet alain
Hi Eugene,
I don't agree with you when you say yes to this question because the second line is a permit and so replacing the first line with deny icmp will permit
http traffic to 4.2.2.2 as the implicit deny is after the second line.
Regards.
Alain.
5 Replies 5
Eugene Lau
Hi Mukundh,
access-list 101 deny ip any host 4.2.2.2  <<----- denies all IP packet to 4.2.2.2
access-list 101 permit tcp any host 4.2.2.2 eq 80  <<--- is redundant as all packets are dropped by first line (ACE - access control entry)
Edit to clear behavioiur up:
access-list 101 deny icmp any host 4.2.2.2 <<------ deny ICMP to 4.2.2.2
access-list 101 permit tcp any host 4.2.2.2 eq 80 <<------ allow only HTTP port 80 request to 4.2.2.2
<<<<<<<<<<<<<<< drop everything else
Thus HTTP port 80 would not be dropped in this type of ACL.
Eugene
Thanks a lot!!!!
cadet alain
Hi Eugene,
Regards.
Alain.
Alain you are correct! Apologies, I read it wrong when I answered yes.
I think I over complicated the description as well when I mentioned that HTTP to 4.2.2.2 would still be allowed Will edit.
Thanks a lot Alain
