Basic question on multicast address (239.0.0.0-239.255.255.255)
news2010a
Level 3
Level 3
For the given multicast address shown below, what would be the subnet mask associated with it? Also, does it make any sense the concept of "broadcast address on a multicast" range? Someone mentioned that broadcast address applies to multicast as well but I am unsure about that.
ip access-list standard ssm-source1
permit 239.254.13.31
2 Accepted Solutions
Hitesh Vinzoda
Level 4
Level 4
I think of multicast addresses not as IP addresses but rather as Group addresses. Fundamentally Multicast and Broadcast are different things. There is no concept of broadcast within a multicast as such. Multicast addresses are group addresses referred as destination. anyone who wants to receive the Multicast will join the certain group, you can also use 239.255.255.255 as your group address for multicast. As far as subnet address is concerned 239.0.0.0/8 just represents the ip addresse range to be used for private administrative purposes.
Moreover, you never assign multicast addresses on interfaces of network devices, this addresses are always used as destinations.
Hitesh Vinzoda
Giuseppe Larosa
Hello Marlon,
subnet mask and broadcast address apply to unicast IP addresses only.
Actually each multicast address is indipendent and represents a session or "channel".
the multicast address is divided in groups.
For example addresses like
224.0.0.x
are link local addresses that cannot be routed and are used by routing protocols.
addresses in range
239.0.0.0 - 239.255.255.255
are the equivalent of RFC 1918 unicast addresses:
these are private multicast addresses to be used inside an enterprise not over the internet.
Hope to help
Giuseppe
Hitesh Vinzoda
Level 4
Level 4
Hitesh Vinzoda
Giuseppe Larosa
Hello Marlon,
224.0.0.x
addresses in range
Hope to help
Giuseppe
Great explanation!!!! Thanks all.
