Basic question on multicast (sparse-mode vs. sparse-dense-mode)
news2010a
Level 7
Level 7
Imagine one is not 100% sure regarding number of hosts and behavior and growth of multicast applications in the network.
Some folks on my team believe that configuring 'sparse-mode' is appropriate. If I am unsure, is there any issue or problem if I configure on my router interfaces 'ip pim sparse-dense-mode'? I mean, why not deploy always ip pim sparse-dense-mode instead of sparse-mode since the former would cover both dense and sparse?
Marlon,
It depends on bandwidth usage on your network. As you know,dense mode always flood/prune multicast packets on your network. Sparse mode will send multicast packets when someone asks for. In case you have a few receiver on your network it would be sparse mode for that. As per your question "ip pim sparse-dense-mode" is a good command as you mentioned. It will use dense mode for group that doesn't know about the RP. For sparse mode 239.0.1.39 and 239.0.1.40 are still flooded as dense. So if you use an "ip pim sparse-dense-mode" command it would be fine. You can also use "ip pim sparse-mode" and "ip pim autorp-listener" to get rid of that problem.
HTH,
Toshi
Marlon,
HTH,
Toshi
Istvan_Rabai
Level 11
Level 11
Hi Marlon,
Sparse-dense mode was introduced by Cisco to support AutoRP:
Initially, when no routers know about the RP(s), AutoRP RP-announce and RP-discovery messages (multicast groups 224.0.1.39 and 224.0.1.40 respectively) are sent using dense mode across the network.
There is a standardized solution to that:
bootstrap protocol.
The following commands configure it:
ip pim rp-candidate
ip pim bsr-candidate
If you use the bootstrap protocol, you only need to use sparse-dense mode.
In addition, as the bootstrap protocol is a standard, your solution will be vendor-independent.
Cheers:
Istvan
Hello Istvan /Marlon,
I agree with Istvan: sparse-dense-mode has been introduced to make auto-RP to work.
only point clearly a mistyping is:
if you use bootstrap protocol you can use sparse-mode only everywhere.
PIM SM provides more control on BW resources used on the WAN links: for the different paradigm : it requires explicit joins and not explicit prunes.
Besides this, Cisco has introduced an alternate way to support auto-RP:
interface command
ip pim autorp listener
see
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_04.html#wp1012925
The issue with ip pim sparse-dense-mode is the fallback to dense mode when no RP mapping exists for a group G.
This can be mitigated with:
global command
no ip pim dm-fallback
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_04.html#wp1013545
So there are many options but bootstrap protocol has many advantages over auto-RP:
besides being multi-vendor it provides the capability to have redundancy also of the boostrap router that is elected dynamically, auto-RP mapping agent is statically configured.
the hash function provides a way to use in load balancing two candidate RPs for a multicast address range.
Hope to help
Giuseppe
Hi Giuseppe,
Thank you for your correction.
I really was thinking forward about something different and mistyped sparse-dense mode.
So the correct statement from me is:
If you use the bootstrap protocol, you only need to use SPARSE-MODE.
Cheers:
Istvan
