Basic Question - Setting an interface to default values
gcossins
Is there a command to set an interface back to default values? Rather than go through a series of no commands?
thanks
mheusing
Router(config)# default interface Serial0
should do the trick.
Hope this helps! Please use the rating system.
Regards, Martin
mheusing
Regards, Martin
knew it would be simple - just couldn't find it
