Basic questions related to Networking
Kuldeep singh
Hello Experts,
There are some questions which is related to Cisco networking:
1. I wants to know which one is best for network to be used as DHCP Separate,
    Windows server or L3 switch (ip pool) ? Plz expalin with reason
2. Everyone knows that switch itself does not have a mac address but
    SVI have mac address then how can we check SVI mac address through
    command.
3. if we use a router, it will have a mac address(only Ethernet not serial).
    suppose i connect one pc to router ethernet port then what status of mac
    will show at ethernet interface, will it be router predefined mac or computer mac ?
KS
2 Accepted Solutions
I would suggest use a windows server- this is what a server is designed to do- as for the switch/router even though they can service this role, they are truly designed for the purpose of switching/routing so running a dhcp  takes valuable resources like bandwidth/cpu/memory.
    command.
Thats incorrect a switch does have a mac address - its a base mac- address, also each svi is alocated a mac address from this base address:
sh ver | in Base
Base ethernet MAC Address       : 00:11:5C:79:95:00
sh int vlan 250 | in bia
  Hardware is EtherSVI, address is 0011.5c79.9542 (bia 0011.5c79.9542)
sh int vlan 251 | in bia
  Hardware is EtherSVI, address is 0011.5c79.9543 (bia 0011.5c79.9543)
The pcsand routers mac address will show so up in the arp table of the router when the pc is connected.
sh ip arp | in x/x
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
3. you mean to say, router ethernet port will show two mac address.
one is Router ethernet port and other is pc mac. Plz correct me if i am
wrong.
If you use the show interfaces command, the router will only display MAC address of that interface...
Router4#show interface fastethernet 0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Lance, address is 000C.5754.6725 (bia 000C.5754.6725)
the show arp command will display both...
Router4#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.1.1.1                -   000C.5754.6725  ARPA   FastEthernet0/0
Internet  10.1.1.15               3   000C.7988.2251  ARPA   FastEthernet0/0
7 Replies 7
    command.
sh ver | in Base
sh ip arp | in x/x
res
Paul
Thanks.
Kind Regards
Paul
2. I read out about SVI that some switch's svi mac address are same
    in cisco 6500 switchs and some switchs like 3750 have different mac address for svi.
    It is not clear to me plz explain with good example.
   wrong.
KS
Hello Experts,
plz see
wrong.
Router4#show arp
DHCP really depends on what you are doing. I have used a centralized Windows server for DHCP of clients, but then use routers with DHCP for phones at different sites because of SRST purposes.
Thanks pdriver and Mark,
My question 2 is still pending,
    in cisco 3550 switchs and some switchs like 3750 have different mac address for svi.
KS
Hello
switches have cam tables where mac-address are stored.
On the 6500's each vlan will use the same mac-address as you have pointed out but each svi vlan has it own cam table which then allows mutiple addressing to use the same base mac-address and avoids duplicate addressing.
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
