prune message on LAN and timer , ip pim
sarahr202
Level 5
Level 5
Hi everybody.
I was reading about the override prune message or joint message.
Please consider the following example:
R1 f0-------------Sw------------------R2---H2 ( 224.7.7.7)
                          R3---H3( 224.7.7.7)
R1 forwards multicast packets 224.7.7.7 onto LAN. Let suppose H2 leaves the multicast group 224.7.7.7
According to my book, following will occur:
1) R2 sends a prune message at 224.0.0.13
2) Both R1 and R3 receives the prune message.
3) R1 will wait for 3 seconds before putting its f0 port in prune state. If within 3 seconds , R1 does not receive any joint message from R3 , R1 will put its f0 int in prune state.
What if we do not have R3 on LAN rather just R1 and R2 and R2 sends a prune message to R1? Will R1 still wait for 3 seconds ?
Thanks and have a great weekend.
Reza Sharifi
Hi Sarah,
The behavior would be the same. When R2 detects that there is no longer any directly connected hosts, it will send a prune message to R1, R1 will wait the interval between prune messages (in yours case is 3 seconds) and then the flow stops.
BTW, according to IETF, the default join/prune interval is 60 seconds.
[Join/Prune-Period] This is the interval between
sending Join/Prune messages. Default: 60 seconds
more info here:
http://www.ietf.org/rfc/rfc2362.txt
Have a great weekend
Reza
Reza Sharifi
Hi Sarah,
more info here:
Reza
