Basic switch configuration
kabeer350
Community Member
hi
I need help about Cisco switch 2960 issue how i give IP address gateway in switch if there more than two vlan  and how configure  telnet command
plz help me
John Blakley
You can have one management vlan available. Let's say it's vlan 1 which is default. To configure:
int vlan 1
no shut
A basic telnet session is:
line vty 0 4
password cisco
You can get more granular with usernames like using local accounts and radius authentication for telnet as well. You'll also need an enable password before you can telnet:
enable secret cisco
HTH,
John
HTH, John *** Please rate all useful posts ***
thanks a lot john
if we create extra vlan and not access any interface and just give ip address and not shut command then it work
Pedro Lereno
Level 5
Level 5
Do you have Lan Lite or Lan Base license (check with "show version")? LAN LITE does not permit routing.
With LAN BASE:
sdm prefer lanbase-routing // save before your config, you may loose some configuration
reload the switch
Example for gateway configuration:
vlan 10
vlan 20
interface vlan 10
ip address 10.0.10.1 255.255.255.0
interface vlan 20
ip address 10.0.20.1 255.255.255.0
For telnet:
username name privilege 15 secret password
line vty 0 15
login local
transport input all
But, do not use telnet (all traffic passes on clear including passwords), use instead ssh if the switch permits:
hostname switch
ip domain name company.com
crypto key generate rsa general-keys modulus 2028
line vty 0 15
login local
transport input ssh
Hope this could help you!
Pedro Lereno
