09-21-2007 05:26 AM - edited 03-05-2019 06:37 PM
Hi all,
I am doing some basic calculations for time it should take to transfer a file over my network. apparently its been a while since I had to do math as I am doubting myself!
I just wondered how long it would take to transfer my 90GB file over a network connection that I knew to be 800Mbps.
So I did the following:
1Mbps = .125MBps
800Mbps * .125MBps = 100MBps
So thats 100 meg a second correct?
1000Mb = 1GB
90000MB = 90GB
at that rate it should take roughly 900 seconds to transfer the 90GB file..or 15 minutes. is this right?
TIA,
R
Solved! Go to Solution.
09-21-2007 07:20 AM
Your basic calculations are correct for time to transmit 90GB across 800 Mbps. In practice, due to frame/packet overhead, and how well stack deals with BDP (bandwidth delay product), actual transmission time might be considerably slower than the calculated value.
09-21-2007 07:20 AM
09-21-2007 07:32 AM
Thanks for your reply. I do realize that this is a perfect world scenario with no overhead and such. I have dis proven that this will ever be the case with an actual transfer, but just for the sake of math...i gave it ago! thanks again
