Basic VLAN map question
news2010a
Level 7
Level 7
A book states that answer b) below is correct. Is the book right on this ?
"VLAN maps can be applied to a VLAN interface"
a)True
b)False
I thought that a) was correct based on the following:
from Cisco.com:
"VLAN access maps can be applied to VLANs or to WAN interfaces for VACL capture. VACLs attached to WAN interfaces support only standard and extended Cisco IOS IP ACLs..."
smothuku
Level 11
Level 11
Hi ,
VLAN maps can be applied to Vlan's.It is true.
VLAN Maps --> VLAN ACLs or VLAN maps can access-control all traffic.You can apply VLAN maps to all packets that are routed into or out of a VLAN or are bridged within a VLAN in the stack.VLAN maps are used for security packet filtering. VLAN maps are not defined by direction (input or output).
Below link gives config details of vlanmaps.
http://cco-sj-2.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12114ea1/3750scg/swacl.htm#77764
Hope it helps you.
satish
smothuku
Level 11
Level 11
Hi ,
Hope it helps you.
satish
