BDI configuration N520-20G4Z-A
Adcom911
I'm trying to get a N520 configured to take over for ME3400 we are replacing. I'm not familiar at all with Bridge Domain being a replacement for vlans. I'm trying to wrap my head around why my config works with the Mgmt-intf VRF  to ping the default gateway at 192.168.16.3 but it does not work under the global routing table with the same configs and setup as the mgmt VRF. I'm thinking im missing something related to the BDI configs??
Config from N520
 vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
no aaa new-model
clock timezone MST -7 0
clock summer-time MDT recurring
ip name-server 192.168.12.12 192.168.12.19
ip name-server vrf Mgmt-intf 192.168.12.12 192.168.12.19
ip domain name adcom911.local
ip domain name vrf Mgmt-intf adcom911.local
interface GigabitEthernet0/0/0
description Env monitor (test)
no ip address
media-type rj45
negotiation auto
cdp enable
service instance 16 ethernet
encapsulation untagged
bridge-domain 16
interface GigabitEthernet0/0/1
description uplink to IRS-switch-Basement
no ip address
media-type rj45
negotiation auto
cdp enable
encapsulation dot1q 16
bridge-domain 16
interface GigabitEthernet0/0/2
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/3
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/4
no ip address
negotiation auto
interface GigabitEthernet0/0/5
no ip address
negotiation auto
interface GigabitEthernet0/0/6
no ip address
negotiation auto
interface GigabitEthernet0/0/7
no ip address
negotiation auto
interface GigabitEthernet0/0/8
no ip address
negotiation auto
interface GigabitEthernet0/0/9
no ip address
negotiation auto
interface GigabitEthernet0/0/10
no ip address
negotiation auto
interface GigabitEthernet0/0/11
no ip address
negotiation auto
interface GigabitEthernet0/0/12
no ip address
negotiation auto
interface GigabitEthernet0/0/13
no ip address
negotiation auto
interface GigabitEthernet0/0/14
no ip address
negotiation auto
interface GigabitEthernet0/0/15
no ip address
negotiation auto
interface GigabitEthernet0/0/16
no ip address
negotiation auto
interface GigabitEthernet0/0/17
no ip address
negotiation auto
interface GigabitEthernet0/0/18
no ip address
negotiation auto
interface GigabitEthernet0/0/19
no ip address
negotiation auto
interface TenGigabitEthernet0/0/20
no ip address
interface TenGigabitEthernet0/0/21
no ip address
interface TenGigabitEthernet0/0/22
no ip address
interface TenGigabitEthernet0/0/23
no ip address
vrf forwarding Mgmt-intf
ip address 192.168.16.97 255.255.255.0
negotiation auto
cdp enable
interface BDI1
description ZTP_VRRP_BDI on vlan 0
no ip address
shutdown
interface BDI2
no ip address
shutdown
interface BDI3
no ip address
shutdown
interface BDI4
no ip address
shutdown
interface BDI5
no ip address
shutdown
interface BDI6
no ip address
shutdown
interface BDI7
no ip address
shutdown
interface BDI8
no ip address
shutdown
interface BDI9
no ip address
shutdown
interface BDI10
no ip address
shutdown
interface BDI11
no ip address
shutdown
interface BDI12
no ip address
shutdown
interface BDI13
no ip address
shutdown
interface BDI14
no ip address
shutdown
interface BDI15
no ip address
shutdown
interface BDI16
description Vlan 16
ip address 192.168.16.48 255.255.255.0
cdp enable
interface BDI17
no ip address
shutdown
interface BDI18
no ip address
shutdown
interface BDI19
no ip address
shutdown
interface BDI20
no ip address
shutdown
interface BDI21
no ip address
shutdown
interface BDI22
no ip address
shutdown
interface BDI23
no ip address
shutdown
interface BDI24
no ip address
shutdown
interface BDI40
no ip address
interface BDI84
no ip address
ip default-gateway 192.168.16.3
ip forward-protocol nd
no ip http server
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip ssh bulk-mode 131072
ip route 0.0.0.0 0.0.0.0 192.168.16.3
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 192.168.16.3
Config from 3750
interface GigabitEthernet1/0/11
description N520
switchport trunk native vlan 16
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/12
8 Replies 8
why you not use Port Channel and instead you use BDI and make Loop?
MHM
I thought BDI is the replacement for vlans on the N520. So I was trying to test vlan 16/bdi 16 on the N520 by doing this setup.
you already config port with tag so no need BDI
correct me if I am wrong
MHM
So I would need to remove the service instance portion of the config?
no ip address
media-type rj45
negotiation auto
cdp enable
service instance 16 ethernet <---
bridge-domain 16
try and remove the 'ip default-gateway 192.168.16.3' from the config.
Also, can you post the full running config of the 3750 ?
Tried that and no luck
vlan 14
name Training
vlan 16
name Management
ip ssh logging events
ip ssh version 2
interface Port-channel1
description Adcom3750X-CE1_VRF RADIO
switchport trunk allowed vlan 4,40,50,65
interface FastEthernet0
no ip address
shutdown
description 5550 #1 DMZDevices
switchport access vlan 10
switchport mode access
load-interval 30
interface GigabitEthernet1/0/2
description 5550 #2 DMZDevices
interface GigabitEthernet1/0/3
description Cisco AP 140AC
load-interval 30
interface GigabitEthernet1/0/4
switchport access vlan 13
interface GigabitEthernet1/0/5
description Adcom3750X-CE1 #1
srr-queue bandwidth share 1 40 40 19
priority-queue out
mls qos trust dscp
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/0/6
description Adcom3750X-CE1 #2
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/0/7
description CCGW
switchport access vlan 41
speed 100
duplex full
interface GigabitEthernet1/0/8
description CCGW
speed 100
duplex full
interface GigabitEthernet1/0/9
description ADCOM_2911_VZ
speed 1000
duplex full
interface GigabitEthernet1/0/10
description Env Monitor
switchport access vlan 16
interface GigabitEthernet1/0/13
description Westminister ISSI
switchport access vlan 52
bandwidth 1544
interface GigabitEthernet1/0/14
bandwidth 1544
interface GigabitEthernet1/0/15
description Civic_DS3_MGMT
interface GigabitEthernet1/0/16
description Adcom-LMR-Switch-B
interface GigabitEthernet1/0/17
description Adcom-LMR-Switch-A
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
description BasementFW1 MGMT
interface GigabitEthernet1/0/22
description BasementFW2 MGMT
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
description To Basement-Training
switchport trunk allowed vlan 8,10-20
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
description To IRS-IT
spanning-tree link-type point-to-point
interface TenGigabitEthernet1/1/2
description To IRS-Lodge
interface Vlan1
description DO NOT ENABLE
no ip address
shutdown
interface Vlan16
ip address 192.168.16.29 255.255.255.0
interface Vlan52
no ip address
no ip http server
no ip http secure-server
I might be completely off here, but can you try and add:
interface BDI16
description Vlan 16
--> encapsulation dot1q 16
cdp enable
No luck with that one. Its just weird to me that I can reach the gateway via the Mgmt-intf but not within the global routing table that has the same routes and config setup.
