Beginner RIPv2 Problems
JDS_Cisco
Hey, I'm new to networking and configuring Cisco routers. I currently have a problem which I can't solve.
I'm in Packet Tracer and I have two routers; A and B. They have a serial link between them, and each router has one PC directly connected to it using one of it's fast ethernet ports via a crossover cable.
I've set the configuration up so that all the interfaces/i.p addresses are correct and the RIP protocol has been configured and the networks set.The two routers can successfully ping each other, and each router can ping the PC that is connected to it. The problem is that a router cannot ping the PC connected to the other router.
How could I fix this? I feel like I'm missing something obvious.
Thanks in advance.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If the routers are actually configured correctly, same true for the host PCs?  Does each have an IP for the correct LAN subnet attached to the router?  Does each have a gateway IP to the router's LAN side interface?
Reza Sharifi
You need to add whatever subnet you are using. For your. PC to the RIP
Example
If the link between the 2 routers is 192.168.1.0/30 and the PC subnet is 10.10.10.0/24 the PC subnet needs to be added to RIP in order to be able to ping from one PC to the other
Joseph W. Doherty
Disclaimer
Posting
Thanks for the replies. The problem was that although I'd configured the correct I.P. addresses and subnet masks on the PC's, I hadn't set the default gateway.
Once I'd done that everything worked fine.
