Bellow 1000 vlan not showing in nexus 5k switch
aguntukkk
Dear Concern,
In my nexus 5k switch  i am trying to adding example vlan 10. cli command is taking but its not showing if i give show configuration.
Please help .
aguntukkk
Yup its VTP issues. VTP operating mode was server when i push it transparent then the problem solved.
9 Replies 9
VLAN store in two different location
try use
show vlan breif <<- to check all VLAN in N5K
MHM
Mark Elsen
  - Check logs on the nexus when trying to add that vlan,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
amikat
Can you please check your VTP Operating Mode ("show vtp status"). If it is configured as a VTP client, you cannot create VLANs on the switch in the range of 1 to 1005.
Best Regards,
Antonin
X5K-CoLoAsia# sh vtp status
VTP Status Information
VTP Version : 3 (capable)
Configuration Revision : 14
Maximum VLANs supported locally : 1005
Number of existing VLANs : 45
VTP Operating Mode : Server
VTP Domain Name : <VTP domain not acquired/configured yet>
VTP Pruning Mode : Disabled (Operationally Disabled)
VTP Traps Generation : Disabled
MD5 Digest : 0x9D 0x30 0xB9 0x2D 0x42 0xCE 0xB9 0x79
0x7E 0x79 0xAE 0x4C 0x28 0xBC 0x71 0x71
VTP V2 Mode : Disabled
Configuration last modified by 172.16.7.5 at 1-6-25 11:34:33
Local updater ID is 172.16.7.5 on interface Vlan1090 (lowest VLAN interface found)
VTP version running : 1
aguntukkk
Sorry but as I know nexus only work as transparent vtp mode
From cisco doc.
""VTP worked only in transparent mode.""
So how it was server mode???
MHM
Thanks alot alot for your reply'
Last W what is exact N5K you have?
Thanks again
MHM
Hardware
cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor")
Intel(R) Xeon(R) CPU with 8253792 kB of memory.
Processor Board ID FOC16102EHD
Device name: NX5K-CoLoAsia
bootflash: 2007040 kB
Kernel uptime is 1 day(s), 0 hour(s), 58 minute(s), 56 second(s)
Last reset at 733142 usecs after Mon Jan 6 10:30:01 2025
Reason: Reset Requested by CLI command reload
System version: 7.3(8)N1(1)
Service:
