BERT
WILLIAM STEGMAN
Level 4
Level 4
I'm trying to perform some testing on the link between my router's E1 WIC and the provider's smartjack and am looking at cisco's ability to do that. I've come up with the following, but can anyone add, remove, update my commands so they are as accurate and effective as possible? I'm running at 2851 with IOS 12.4(9)T1.
<configure interface for loopback mode>
Int s 0/0/0:0
loopback
______________________________
<Run The Test>
bert controller E1 0/0/0 pattern alt-0-1 interval 10!
<Output>
Router#show controllers e1 bert
Controller E1 0 Profile default : Test Never Ran
Controller E1 0 Profile 1 : Test passed with BER of 10^(-2) --> [wow Media is OK till the looped end]
thank you
mbroberson1
Level 3
Level 3
First off I run in to these issues from time to time. I would strongly suggest taking a look at the following document and troubleshooting steps to isolate the issue.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a754b.shtml
HTH,
Brandon
